XC540 Cut Alignment Problems
Creen
We recently purchased a used XC-540 Soljet. We've been having glitches with the cutting after lamination. It would stop half way through the cut and never continue. We would have to reboot everything in order to run it through again.
Now the problem we are having is that all cuts are 1/8" off to the right. We did a print/cut adjustment as on the roland support page and it was perfect. Has anybody had this issue before and if you did, how did you fix it? We've talked to tech support and they were of no help.
Thanks!!!
