Zund Cutter G3 L-3200 error 28F03
Andre@Beith
Hi need some help on a Zund G3 error 28F03 zero mark of t-axis not found on the universal module
Have replaced the drive belt and zero mark sensor.
Is there a specific way to install the belt to see the zero mark?
congdesign
Have you solved the error code??
We It is the l2500CV model.
error code - 342 (AC Fault Polarity Y-Axis)
error code - 312 (AC Fault Check Axis
error code - 307 (AC Fault Check AC)
I have that code
ToTo
Professional Support
Does it start to rotate during init?
Prevent direct sunlight onto sensor.
There is no specific position belt/sensor
