2 5x10' alumalite signs
J
john1
Guest
Hey guys, Just wanted to see where i would be at with this job to see if there is maybe some things i'm not accounting for.
2 identical 5x10' alumalite signs with full color laminated digital print applied to 1 side only
Customer has vector artwork and all (imagine that!), All i have to do is print (outsourced), apply to substrate and deliver. The one is going to be installed by me but i am still putting together the quote for that one.
I have $756 in time and materials using 1/4" and $852 using 3/8".
1/4" $903 each, 3/8" $999 each - If i wanted to i could come down a tad on the substrate mark up (100% each) but if i don't have to i'm not unless it's make or break this deal. Even as low as 50% mark up each i'd be making good money.
Thanks!
Circleville Signs
Personally, I think you're pretty high. For 1/4" Alumacore (alumalite), 5'x10', single sided, I'd be right at $750 ($15/sf).
I dont' mess with 3/8, I'd go straight to 10mm. On 10mm, I'd be at $950 ($19/sf).
I'm on the high end of things in my area...
J
john1
Guest
Shipping would be a killer on 2 5x10' alumalite sheets from a vendor printed and all.
SignManiac
Just got the go ahead on a double faced 5'x10' on polymetal. Install 2 miles away on two post for $3400.
Temp sign. At first I was going to price $600 less but thought better. Glad I bumped it up.
J
john1
Guest
Thanks everyone, Did some re-working on found a few areas that allowed me to make good profit and come down a bit also. I re-worked my installation time on each print to the panel and came down on the mark up on the substrate some. I'm at $757 per sign on 3/8" now. I'm not going to give the 1/4" option unless they say something after the quote about if there is anything cheaper.
Thanks again
Malkin
I assume 1/4" = 6mm and 3/8" = 10mm for the purpose of this post, unless there is something I don't know.
We would be around $1,200 each for 5x10 full color (cast vinyl/cast lam) on the 10mm.
As others have said, we're not the cheapest around. Would probably get the job if a regular customer, but if someone's just shopping around on price I'm sure they'll get someone else, or order a smaller sign.
