Hey John,
I don't think I'm too bad, but youre right, I am a little low. Since I use estiating software, I should have double checked my figures by multiplying my material cost x 4. That would put me at $1500 for the
sign and the install would be additional.
The way I came to my price is by using 2 - 4' x 10' sheets of 3mm white Dibond and lettering with HP vinyl. I also assumed that it would be a local install and I would be mounting it directly to the brick wall. My material costs, would be under $400. Labor is estimated at 7 hours for design and production, and the install should only take a few hours by myself.
If I did it the right way, (like you said and added a frame) yes, my price would be significantly higher, and probably in the $2k range before the install. However, I would definitely need help on the install.
Anyway, the
sign pictured below was about 5' x 18' and what I would call a framed aluminum
sign, similar to what you described. It's reinforced with 1" square tubing on the back, similar to what's shown in the second picture. IMHO, this is the proper way to fabricate a
sign and mount it on brick or on just about any rough surface. I would also do as you suggested and blind mount it using "L" brackets from behind.
If memory serves me correctly, the
sign was about $2200 and install was about $600. The
sign outlasted the business
Checkers
