21'x4' aluminum sign Pricing Help
n20capri
Need help quoting this out...my biggest job so far...
2 lines of text (using Oracal 851 or Avery A9 - have had great luck with both)
Blue text - "Wholesale Auto Service" Approx 20" high
Red text - Phone Number Approx 16" high
Nothing fancy in the way of design (his words not mine - lol)
Would have to be mounted on a smooth substrate first as the building is brick. The area is 21ft x 4ft and I was thinking aluminum sheeting...a couple sheets pieced together. Would apply the vinyl at my shop then deliver and install, so the price would of course include installation which is about 15ft off the ground.
I was thinking approx $1,100 installed.
Any help is appreciated
Thanks,
Mike
OldPaint
4X21' lettering @ $10 sq ft=$810.00, 3 sheets of .040 aluminum...@$60 each = $180.00. as for the install youre gona need an extra pair of hands, maybe a lift......
youre $1100.00 is a low end price....with instalation.....
can you do it for $100.00???????
I think you’re price is a little low also. If you could get by with a 20’ panel, you’ll lower your costs drastically. I’d then be about $1,000 for a 4’ x 20’ and not knowing the installation [how high, any obstacles on the ground, two guys, solo…] maybe about $500. for the install.
n20capri
Awesome, thanks guys...thats why I asked...
I think....I said THINK (lol) I found a local metal place where I can get a good deal on the substrate...That will help alot...going there tomorrow to see what the deal is.
Def need a second set of hands though...
Much appreciated,
Thanks again,
Mike
Checkers
WOW Joe and I agree on this, low is putting it nicely :smile:
I'm at $1061 just for the sign - using .040" aluminum.
Then you're saying it needs to be mounted to another substrate before you install it on the building? Even if you just 3 mm coroplast as a backer, you'll add another $100 to the price. a real substratewould be double that.
I won't leave the shop for an install for under $150 when there are ladders involved, and a sign that size, that high up could easily be in the $250 - $350 range.
Anyway, a fair price for me and my client would be about $1600 installed. I would use a more rigid substrate - like 3mm Dibond, cut the sign to 4' x 20' and assume the install was local with no headaches.
Also, I would provide a sketch for the permit which he would be required to pull. There's very little that is worse than you getting fined becase you installed a sign without a permit.
Checkers
skyhigh
Mike I did a 21 x 4 two years ago for $2100 which included install. I couldn't reduce it to 20 ft, as it needed to fit between 2 pillars. I used 3) 4x7 panels ( I wanted them to be even) plus I installed with angle on the back of the sign, so no screws thru the face.
Brian I think your a little low....but I'm pricing it out figuring on 3- 4x8 panels (with 1ft waste on each...no deduction)
Mike, I see your in PA.... I hope your not near me. hahahaha (JK)
OldPaint
i agree that doin a NOMINAL SIZE rather then that added 1 foot...will make it a lot better lookin as for seams.
4'x10' sheets of .040 are available....2 sheets with center seam....would look a lot better the doin 3 7 ft sheets!!!!
n20capri
No No No...the aluminum goes right on the wall of the building!! :)
Yes I was def thinking of slimming down to 20'
skyhigh - I'm near northeast Philly...
Thanks for all the feedback everyone...much appreciated. :)
Si Allen
Since you are near Philly...look up a large sheet metal shop. They buy coated aluminum in large coils. Have them cut you a 21 foot sheet and roll it up. No seams and lots cheaper that a bunch of sheets.
We have to agree with SkyHigh here. We get more than $1100 for mdo, directly bolted to building. This would be something like $2000, if it were two sheets (installed). If we were required to do three sheets, probably about $2400 installed.
Here is what you need to keep in mind. There IS good money in stuff like this BUT it is not a fifteen minute job, unless you have two booms at your disposal. When dealing with the stuff this size, the wholesale costs start to skyrocket. In other words, the tools cost more (drill and bits), more bodies and hands, etc. etc. All that will cost you more, and will come right of the top of your profits.
Checkers
Hey John,
I don't think I'm too bad, but youre right, I am a little low. Since I use estiating software, I should have double checked my figures by multiplying my material cost x 4. That would put me at $1500 for the sign and the install would be additional.
The way I came to my price is by using 2 - 4' x 10' sheets of 3mm white Dibond and lettering with HP vinyl. I also assumed that it would be a local install and I would be mounting it directly to the brick wall. My material costs, would be under $400. Labor is estimated at 7 hours for design and production, and the install should only take a few hours by myself.
If I did it the right way, (like you said and added a frame) yes, my price would be significantly higher, and probably in the $2k range before the install. However, I would definitely need help on the install.
Anyway, the sign pictured below was about 5' x 18' and what I would call a framed aluminum sign, similar to what you described. It's reinforced with 1" square tubing on the back, similar to what's shown in the second picture. IMHO, this is the proper way to fabricate a sign and mount it on brick or on just about any rough surface. I would also do as you suggested and blind mount it using "L" brackets from behind.
If memory serves me correctly, the sign was about $2200 and install was about $600. The sign outlasted the business :)
Checkers
skyhigh
Here's a similar one. Not a great pic, but I thought the sign turned out nice. Lots of snow anyways.:Big Laugh
Pro, even with 2 booms, its still not a 15 minute job.:cool:
Checkers
BRRRR! I'm glad I'm south of you :)
Nice job, you did the client well. Especially considering it's a large, wall mounted sign. It doesn't have a "strip mall" look to it.
Checkers
skyhigh
The colors were kelly green and navy blue (looks black in the pic). Thats me in the bucket, how do I look?:Cool 2: COLD.....I mean COOL.
Nice job skyhigh.
Did your bucket freeze in place from the bitter cold and you had to climb up that ladder to get in it ?? LOL
Both jobs look nice.
Sky - It was more of a figure of speech, but you already know that. I am curious about Gino's question - did the hydraulics freeze, or were they just screaming for mercy? :biggrin:
Long ago, we would tackle jobs like these, with big trucks and freakin' ladders. "Not no more!". To the unknowing, these jobs start out looking like cute bear cubs, only to leave one realizing that the 'lil cute bear is a damned grizzly. Today, we tell people 10 to 12 feet. After that, we get the guys with the booms/cranes to deal with the installation.
skyhigh
The hydrolics just scream for mercy.....lol
As you can tell, I like the vans. As for the ladder, I don't know where that damn thing came from :Big Laugh
Actually, if you look close at the pic, there is a short roof at the bottom of the sign. The ladder was for my helper to attach the screws under the bottom lip of the sign. I know he didn't take this picture, so he's either taking a break or building a "snowman esq".
Don't feel too bad for me.... the bucket has a heater in the bottom. I think I had shorts on that day.....LOL
SAS
I'm doing a 4 x 20 this week I'm not doing the install but wanted to know what kind of options is there so you don't have to screw through the face. I was going to make a aulm. frame and weld small pieces of flat alum. with holes to the back of the frame to mount it to the wall.
Oh yea back to this thread I'm charging $1500 for 2 4X10 alumalite panels (no frame) but it's printed.
signage
If you make a frame out of either square tube or angle you could mount a piece of angle to the wall and screw into the leg of the angle through the frame.
