My wife and I say the amber RapidTac smells like Bailey's...hahahahaha my boss loves the smell of 180CV3
is this bad or what, I have to admit I like the smell of Rapid Tac, smells like vanilla, lol
Every rolls... depending on the level of matte spots, I run the heatgun and it turns gloss again. Better for print n' cut as you can heat only the individual letters you want gloss back.you know what really smells bad, when you cut acrylic sheets on the panel saw, instant headache.
Changing subjects: Has anyone noticed near the end (last 20-25 feet) of lamination rolls, a "modeling or hazy effect" especially with 8518. It looks terrible on dark color backgrounds of vehicle wraps. What do you all do, just waste it.
Wow, that's interesting! It’s funny how the smell was actually kind of pleasant back then compared to the strong chemical odor we’re noticing now.I also miss the old High Performance Automotive Grade from 3M. The adhesive smelled like apple juice (kinda). My van was full of striping rolls when I was doing dealerships back in the days. Adhesive was also visually recognizable by the tint: a li'l darker than usual. Never understood why they dropped that line. It was especially made for automotive clearcoat. They also had some amazing colors, never seen in regular sign films.
But that smell...![]()
The reasons could be anything from chemicals needing to be sourced from other manufacturers because of shortages or just cost, advancements in vinyl/ adhesive technology put into service, could have something to do with the ever increasing regulations on chemicals, so formulas need to be modified to reduce usage on select ones. Believe it or not, some of the "not so bad" chemicals can actually smell worse than the really hazardous ones. Things change, the reasons are endless... I haven't had any complaints about smell after installation, so as long as they work like they should...Do you think the formula changes over the years could be what’s causing the stronger smell in today’s vinyls?
That makes a lot of sense, especially the part about regulations and supply chain changes forcing adjustments in formulas. I hadn’t considered that some “less hazardous” chemicals could actually smell worse, that’s really interesting.The reasons could be anything from chemicals needing to be sourced from other manufacturers because of shortages or just cost, advancements in vinyl/ adhesive technology put into service, could have something to do with the ever increasing regulations on chemicals, so formulas need to be modified to reduce usage on select ones. Believe it or not, some of the "not so bad" chemicals can actually smell worse than the really hazardous ones. Things change, the reasons are endless... I haven't had any complaints about smell after installation, so as long as they work like they should...
Yes,
The laminate on the clear liner
Smells like skunk when it comes off / applied
