J
john1
Guest
Hey guys, Have a guy wanting a 3w x 6t' aluminum sign. Putting it on .063" aluminum pre-painted white 1 sided.
Will be applying digital print to this as it has TONS of text lines. Artwork will be a separate charge as it's a detail shop sign with all these crazy packages which is why I'm not doing cut vinyl
I did some math and i have to buy a entire 4x8' sheet and have it cut down which that cost including cutting down is $88 from a supplier. The digital print will cost me $163 from a wholesale member with a bigger printer than mine on 3M 180C. I'm in a tight spot on things like this due to alot of you guys will use the scrap pieces on other jobs, It may take me easily a year or two to use them up so i must charged for my entire material cost. Reason why im only doing 50% mark up on this quote
I was thinking $427.25 finished without design but i think it's too high, I feel terrible about not being able to price things out even though i did my shop rate math and put in my time involved.
Here is what i did:
Print with 25% mark up $203.75
Aluminum with cutting marked up 50% $133.50
Install 1.5hrs $90 ($60/hr)
Graphixcalc is telling me $330 with 50% mark up on substrate but i can't make heads or tails of that thing
Thanks guys!
Here is what i did:
Thanks guys!
