Admin username and password HP Latex 800W
DeeDBLu
I for the life of me cannot figure out how to setup an admin username and password. Any help would be greatly appreciated!
balstestrat
Problem Solver
Access the printer IP with web browser and select some security setting from the left.
It will force you to set it. For the sake of the service guy, I would set it to something simple... like admin.
DeeDBLu
See when I do that it's almost as if there is one set already and I don't know what it is. Just asks for the credentials but doesn't give me an option to set a user name/ password.
balstestrat
Problem Solver
Then it's already set probably by the installer. If it's not admin admin, contact who ever installed it.
DL Signs
Never go against the family
If that doesn't work, you'll need to do a factory reset to enter new ones... But it's different for each model. Contact HP support, and see if they can walk you through it.
ikarasu
Don't factory reset... You'll lose all your profiles ( unless I'm wrong?)
Get the service pin, or get your tech to come and enter it. It'll tell you what the username and password is.
DeeDBLu
Hey thanks guys! Several limitations faced as I am based out of Bermuda. The company I work for wanted to save a couple bucks and bought the printed through an import company so yeah... Printer just showed up one day and I did the installation although was never prompted to set up a username and password.
balstestrat
Problem Solver
If that is true then someone at your company has set it. It doesn't come preset from factory.
Can be reset in service menu.
