I have a cut-out of many pieces cut from 6mm expanded PVC in two colors. This is some unknown being's clip-art creation, certainly not mine. I'm just implementing it.
What method did you use, how did it go?
The thing is 60"wide and ~32" high. It's going to be applied to an interior finished drywall with VHB tape. I've stuck lots of stuff to wall before but never anything with this many pieces.
I thought that I'd print and cut the entire image on a chunk of PhotoTex, put it on the wall, stick the cut-out pieces in their places, and remove the PhotoTex. I printed and cut the image, in two pieces, but the I got to wondering just how I was going to get the two pieces of PhotoTex on the wall. If I use application tape the adhesive in the app tape appears to be more aggressive than the adhesive in the PhotoTex. This would not make for a fun installation.
I absolutely do not want to use a pounce pattern, for many really good reasons, I thought of printing the image on
paper, tape it to the wall, and using a small awl indent various cardinal points for each of the pieces of the cut-out, then remove the
paper and apply the pieces to those indents. Not particularly satisfying nor as accurate a method as I need.
So here I am, asking for a solution. I like the PhotoTex method if I could figure out a way to get it on the wall. Failing than I'm open to any and all suggestions.
