Advice on Size of Plotter to Purchase
JulieS
Hi! We need to purchase a new plotter to replace our 24" Graphtec. Planning to go with another Graphtec, but not sure which size would be best. I'm thinking 30" (since we also have a 15" Gerber and a 54" Roland Print/Cut). I'm concerned that anything larger would be more difficult/slower to load. And since I'm not a weight-lifter, I'm not sure I can handle vinyl rolls larger than 24". Any thoughts?
Thanks!!
Dennis422
The bigger the better.
I would go with 54" so you do tie up your printer while cutting.
The cutter is not that heavy, but the rolls might be.
But then again, you will not be cutting much of the color rolls that are wide. It will be mostly a printed vinyl that will be wide
MrSalumi
Pretty much word for word what my response was going to be. Bigger the better. I know of a good cheap Summa D140 Drag for sale if you are interested PM me.
ExecuPrintGS
we only have a 24" plotter here and its rare that i really need anything larger. When i do i load it on our roland or mimaki printers since they will also print and cut.
To me having a 54" plotter and a 54" printer plotter is a little redundant. the 24" plotter is fine for 99% of what we need for just cut vinyl. Anything printed gets cut on the roland or mimaki anyway.
im sure different shops have different needs though
Mosh
54", you can still load 24" film into it, but have the option of sizes all the way up to 54"
OldPaint
i have a CX-300 roland...30 INCH........but use 24 inch mostly........but if i need to cut something 30 inch......I CAN)))
