Ai help please
Bigcat_hunter
What am I doing wrong? I am trying to combine a font (converted to outlines) and a splatter effect using the pathfinder tool.
I place the splatter effect over the text, and use the "minus Front" tool in pathfinder. It eliminates every letter but the first one. See attachments. Any help would be appreciated. Sorry I am still learning Ai after using Freehand for my the last twelve years.
Vinylman
I had a similar situation several years ago.
If I remember correctly, what I did was "UNGROUP" the lettering, {THEN}, make copies of the distressed effect you want to use { ONE FOR EACH LETTER}.
What I did then was to take each letter separately, overlay ONE of the effects, and follow your original idea of " minus front", then repeat for each letter. once completed you should have all the letters distressed, and you can then line them up and group them together.
Bigcat_hunter
Thanks I will give that a try.
JLD984
When you convert the text to outlines, ungroup the letters then combine/weld them to make them all one object. That way you only have to subtract the effect from the text once, instead of once for each letter.
ddubia
My suggestion was gong to be what BigCat mentioned.
JLD, I'm going to try your suggestion as I've never done that and it would save some time and aggravation.
GAC05
Quit buggin' me
That effect you are going for does not look like it will be plotted (or shouldn't be).
If you are going to print couldn't you make the letters a clipping mask and clip the grunge effect inside them?
wayne k
guam usa
