alum sign
davidcarr87
ok, i have to give a quote for a 8'x10' .050 ish alum sign..
my supplier only sells 4'x10' sheets
so it would be 2 pieces unless i can find a local place that can sell 8'x10'
their getting 2 8'x10' signs--i called for pricing and they said 1-4'x10' super bright white .063 aluminum sheet is like $95. reg $150.
so that would be around $200 in alum sheet for 1 sign..not counting H track or what ever i connect the 2 with..
what my question is..how much do you guys normally mark up stuff??
and what would you use if anything to join the 2?
there is a 1 1/2" square tube frame..but the supports are not set up to be at the joints on this sheet metal
its for a vol. fire dept..and they get city/county funding...their right on a major highway...they said cheap so i said banner..they said they want alum..so i said ill get on it..lol
they said price doesnt matter but i dont want to over/under bid...
as of right now there will be cut vinyl going on the signs...trying to talk them into putting their logo on it as well...then it would be a print..
sorry its so long..
davidcarr87
what kinda markup are ya'll doing on the alum??
normally 200-300% markup is what i do..but not sure for this..normally we deal with smaller signs..sorry
davidcarr87
not tryin to be rude..but it will take more material than just the alum..
i was asking the markup on the aluminum ....i get that the alum will cost 400 for 2 signs..and you charge 1400 for 2..
and thats 1000 extra..
what i was asking is this..
was that 400 in alum sheeting marked up x1 or x3??
ok..for 1 sign
i norm mark substrates up 200-300% so.. ($600-$800) for alum
charge 50 for layout(simple txt and maybe logo)
$6 sq ft --80 sq ft= $480 for vinyl
that is $1130-$1330
my hourly overhead is $50 an hour. Im a 1 man shop
not sure if i should just butt the 2 sheets together..(afraid they will eventually not line up)
or if there is any type of molding or track out there that will work(been searching the forum for a hour or so)
thanks for all the replies...does my pricing method seem right??
CentralSigns
I don't get hung up on $$$ and time. I have a real good idea on market value and rarely miss. It's good to know completely what the composition is charging, mine is a drunk and has to charge a 40 of whiskey:bushmill: every day so that puts him at the top of the scale.
Market value includes delivery, install and 1/2 hour art time. I often look at square foot pricing. $15-20 per square for aluminum, Lexan. $1400 was low side for up here, could get as much as $2000 for the same sign here in Western :Canada:. I was assuming simple layout 2 pieces put together onsite. Try to keep text from appearing on the seam. You could also put the piece together in shop and apply across the seam. If it is 15-20 feet from eye distance the seam will disappear. If the alum was white you will not use $480 worth of vinyl dude. hope my comment helps.
davidcarr87
lol it helped a lot..
and the sign will be around 20' off the ground(to the bottom of the sign)
i know i will not use $480 worth in vinyl...
guess i just need to call the local shops..one of them i work with a lot and we help each other out..but he is bidding on this job as well so he will not give me any input :p
thanks a bunch tho :D
