Another price check!?
Holeshotrob
I am putting graphics on four acrylic signfaces. Two businesses sharing one double faced sign. The faces are 4x8 ft. and are aprox. 20 ft. up on a pole.
The graphics are simple designs, 3 colors on one, 2 colors on the other.
I am charging $1000 per business, as they agreed to do both at the same time (quantity discount). I normally charge around $1200-$1400 to replace DS sign faces.
Am I in the ballpark, or am I striking out?
Thanks alot
ps- I am not doing the install
Ken
When I think of an acrylic sign face I automatically think of a back-lit sign. So, are you therefore providing two sheets of acryilic? Or is this one opaque sheet, lettered both sides? If so, why not go with an aluminum composite( reynobond, alumalite etc) or even a sheet of pvc.?
Your quote, not knowing all the details, seems high to me.
Ken
ovrcafnatd
Hey if you can get that price per company - more power to ya!
I would probably (unwillingly) be a bit lower myself - using 3/16 acrylic (not lexan)
but hey you are using 3 colors. ;)
It sounds as if you are re-facing a 4x8 cabinet. You do not state whether they are flat or pans BUT we would probably be about somewhere around the $2500 to $3000 range (and that still can be considered cheap). After all, they are 20 feet up in the air, in which we would be subbing it out to an electrical contractor.
If permits were required, we would be talking even more money.
MAB SIGNS
I just did one 2-color translucent panel with a digital print in the center for over $500 and it was 60"x60". Bump up your price if not too late. I wouldn't discount more than 10% for each.
Holeshotrob
The sign is aprox 8x8 backlit double sided box with flat faces. The sign faces are stacked on top of each other with a dividing rail in between. Total of 4 sign faces. I'll post up a pic tomorrow.
The main business is my wife's place of employment, so I'm giving them a decent discount (they are only paying $800), while the business next door is not a regular client, so I'm charging them closer to my normal price. They are getting a qty discount of $200. ($1200 instead of $1400)
ps- I decided to install...making them split the cost of bringing in a lift. I will prolly charge 25% on top of lift cost.
Ken
The plot thickens...
See Rob, you didn't give us enough info first time around.
Rob Allen has lamented about this on many occasions. When asking for an opinion on price, or anything, it is best to "not hold back" ..sometimes, the details make a difference. For instance, you did not state the customer was related, that they would pay for the lift, that you are actually doing
128 sq. ft of signage....... makes a difference, yes?
Regards...Ken
no offense meant here I just do not understand the concept of giving your wife's place of employment a discount. In my experience these are typically the jobs that you give 110% to as you have a personal interest....don't wait for your enemies to make you rich, it is your friends that are going to do business with you (or at least friendly customers). I believe I should be compensated fairly by EVERYONE that I do work for friends and family included....but anyways...
4X8 replacement faces (3/8") with one color lettering I would be at $1230 per panel price does not include installation, permits, or recreation of artwork which are all billed at $125 per hour.
Holeshotrob
Thanks for all the input everyone. I really appreciate it. The reason that I'm giving the employer a discount is that she helped us out with some things when I was laid up with knee surgery. I just wanted to find out if I would be in the ballpark with my regular pricing. Apparantly I was a little off, but the situation will be rectified.
again, thanks alot everyone, and Happy New year.
