Anyone using PR-200 printable primer on acrylic?
artifacture
I have a JFX200-2513EX with two white and two clear channels running LUS-150 inks. I'm considering replacing a clear channel with primer and want to know what the potential downsides are. We don't really use clear currently. We print almost exclusively on acrylic, and without primer we see adhesion issues. Hand applying primer to full size sheets is a nightmare to get even application and no streaking. This would allow just putting primer where it needs to be.
So I'm wondering, does this primer work well for acrylic? Are there issues I should be aware of? For instance, I'm told it clogs more often. I just want to make sure I won't regret making the change and that it yields the convenience I'm looking for.
I honestly don't know how well it works on acrylic but from a technical standpoint, it's definitely tougher on the head. It's hard to say exactly how much life it takes off a head but it will fail sooner than it would have with regular ink running through it. So maintenance will be key. Also, if you switch, you need to get a new, special sub tank for the primer that is more resistant to the chemicals in the primer.
Smoke_Jaguar
Need to do a lot of stuff to swap to primer, and yeah, it is bad about nuking heads. Might want to look into brush-on products or pre-treating acrylic. I tend to get good adhesion on LUS150 + acrylic by only removing the protector right before printing.
artifacture
Yeah, they gave me a list of parts that would be replaced as part of the swap, though a tech we talked to said since our system is only a year old, we might be able to get away with some of the parts after a proper flush. Damaging the heads is not good to hear though. We are good about cleaning it every day that we print which is most weekdays. I know there used to be a different cleaner recommended, but a tech said that was no longer recommended.
On extruded acrylic, the LUS-150 does reasonably well, but on cast acrylic it's much more common. We laser cut after printing so we apply a liquid masking that dries to a plastic film and remove it after. It's always when peeling that when the failures occur. It's never wholesale failure, it's just random spots but enough to need to reprint. We have the Natron primer because the Mimaki wipe on primer didn't seem to work well for us. The biggest challenge is trying to evenly apply it to a 4x8 foot sheet. Too much and it can leave streaks. We have a window washing extension arm with a pad to put it on and one to wipe the excess, but that gets enough on it that it starts to redeposit.
Smoke_Jaguar
Wipe on primers will be a ton more aggressive than anything that you can put through a head. If you those don't work, Pr-200 is going to be hilariously terrible.
artifacture
The primer we're using works, it's just a nightmare to try to apply it consistently to a 4x8 foot sheet. We end up having to climb onto the table on hands and knees and buff the acrylic to get rid of streaking and sometimes it never goes away.
Smoke_Jaguar
Get a sample and try applying it by hand to see how well it works. If you need some, I think I have 4-5 liters of that nasty stuff kicking around I can send you.
crashaffinity
we've got pr-200 loaded in our UJF-6042 MKIIe and it works fairly well on gloss acrylics. No adhesion issues. On non glare acrylics and matte rowmark it still fails (on raised text / braille). For those pieces we use AP3155 adhesion promoter diluted 15:1 with isopropyl alcohol, and we find that works amazingly. We generally only run into issues when we're doing raised text / brailled though.
Haven't had any issues with the pr-200 degrading the head, it shares a head with the clear ink and haven't noticed any issues.
Smoke_Jaguar
This is a pretty typical scenario with me on the UJF MKIIs with primer, the primer nozzles are mostly fine, but it reacts with the clear ink and cements in place. The Gen5 heads on the JFX200/500 are more durable in some ways and have a single unified nozzle plate and are easier to clean. It's not a guaranteed issue, but one to be mindful of. Good to see if the swap is worthwhile before committing to it.
crashaffinity
Interesting, how old is that head? We wipe our heads between every print with a physical cloth and we have no build up, been doing it that way for a year.
Smoke_Jaguar
Usually happens when the printer sits for a few days. Usually fine, but since ink and primer share a capping station (there's 2 sections, connected with a Y fitting). Heads naturally drip and it's a good thing, keeps clogging from being as much of an issue. Since the ink reacts with the primer, it can catalyze. Most people are scared to touch the nozzle plate, good to wipe them down. Just have to be gentle, use a clean surface on each swipe with a Texwipe and some flush or maintenance fluid 15 (or similar) and you're fine. Also applies to Gen5 heads as well as the UJF's CE4 heads.
First UJF 6042MKII I had was a toasted #1 head. About 70% of primer channels worked, 3 nozzles of clear. If it was on a separate head, I could see it being less of an issue. Suction wiper in later revisions helped, however the JFX200 (and EX variant) just uses blade wipers.
