Anyone want to ballpark this?
weaselboogie
2x5 Digital print with lam mounted on .080 ga alum. Single sided
4"x4" x 8' posts with decorative curved wood top and bottom (4' wide, jigsaw cut), brace across back behind sign, dark stain and waterseal.
Installation, 2 - 3' holes, cement footers.
This is a semi-perm sign for a new allotment. Estimated life is 5 years until they replace the sign with a larger carved wood sign.
Steve G.
I'd probably use Omega bond instead of .080 just for price...
3 mm Obond panel cut to shape would be 165
design / layout 65
print installed 120
posts , rails and hardware - stained,assembled 225
install with concrete 390
total 965
steve
Jillbeans
Can't help you with a price but I will second the OmegaBond suggestion.
It's some good stuff.
Love....Jill
Sign_Boy
I know I'm not talking price here, but that would look cool carved or blasted. JMO.
I agree with not using the .080
weaselboogie
That's what I'm hoping the next one will be. I don't know why they want a semi-perm instead of just putting all the money into a permanent solution. They're wanting this to last 4-5 years until the lot fills up and replace with a really nice sign.
Sign_Boy
Good luck getting them to change it out in 4 - 5 years.
IMO give them the option of both.
Show them the difference in cost.
Maybe they will change their mind when they realize what they will save in the long run and how much better it will look.
Do you have a sample of a carved or blasted sign to show them? That should do the trick.
JMO
