AUTOMATION and WORKFLOW
Sortrac
It’s great reading you guys!
Everything seems to go back to workflow software rather than automating hardware.
In that line of thoughts, i am already in the process of building a software that theoretically will check a lot of those boxes, although i am stuck in one of the final stages, being how the work orders are presented, and the way they are handled. Since we can have a few hundreds at a time, it’s hard to have a good « overview » of everything to do. So far I set them up in « due date order » but we can only see the first 10 or so in our list. I’ll try to take screenshots tomorrow to show where we’re at visually, and try to give you the short version of what we we’re aiming for. I would be really interested in hearing your thoughts and recommandations for the last mile. (Around a year long project so far)
As for the budget for any ameliorations, i am looking to stay below 200k in the next two to three years, towards anything that will smooth out our processes, and allow us to shift to the next gear.
Thanks a lot for the input so far! Keep it up!
  • Agree
Reactions: 1 user
Pauly
Printrade.com.au
To automate hardware, you need software.
In the game of automation, you need to start small.
As you said :
I’m trying to figure out the best way improve my shop’s workflow, wether it’s by automating some processes, or finding a better process than having hundreds of work orders printed out and scattered around the shop.
A workflow automation like i've demonstrated is something you need to do first. remove the paper, have everything in 1 system.
Machine automation only works when you have specific products, no customer orders etc. But all that automation is generally in software unless im missing your automation point.
Like automatic feeders, better finishing equipment etc.
But the key is to start with automating small processes. implementing workflows,
Visually see the bottlenecks, are things organised, can your workers find the right tools, is there always stock,
Small things.
  • Agree
Reactions: 1 user
ONYXtechtips
It was enough to scare me off, but we're a smaller shop/team. I want to say $2-3k setup then something like $15 - 20k a year?
The list price for ONYX Align is $5520 for a one year subscription and $3395 for training. Training involves in depth creation of products specific to the needs of the shop including all costs associated with the manufacturing process. There may be current promotions that you could take advantage of if price is a concern.
  • Informative
Reactions: 1 user
myront
Dammit, make it faster!!
We used to have baskets hung on the walls strung out all over the shop. New jobs here, different basket once proof is set up, another for needs revision, another over there for approved, another back across that way for the print tech, back over here for production.
Been using the free Trello version for a few years now. Old school boss isn't too thrilled with it but we love it. Everyone has there own login so they have their own avatar.
We have tabs for each of the different phases
And the first board looks like this. As a designer I've chosen which "lists" should be my primary focus by just collapsing the others. Each job is called a card. Once I've completed my part I just drag the card to the next appropriate list or I can move it to another board altogether. Once you open a card you'll see any attachments, instructions and the proof etc. You can also write notes to corresponding people that are on the cards.
  • Hilarious!
Reactions: 1 user
GaSouthpaw
"The downside of any automation is you will never find a canned solution that will do everything you want or need and all automation implementations will take a lot of labor."
^^^ This right here. A lot of shops will buy/subscribe, then get fed up because of the work required on the front end and abandon a good system. I've seen it more than once, and it baffles me. There's a learning curve to pretty much every new piece of software/equipment/etc.
You should find someone to help you automate if you are not enterprising. I work with consultants who can help me see what I'm missing, but I enjoy building, so I do all my coding and building in my automation tools. Automation is an everyday function that takes eyes and hands to shape it constantly; there isn't a one-and-done solution in our industry simply because we are ever-evolving, and the situations we deal with can differ from client to client and job to job even.
Our automation flow involves a front-end web2print, pre-press/process automation tool, Onyx as RIP processor, and then processes and workflows purpose-built by the team for everything we do on each machine. The most important thing I can say for me is to work backward. Build effective and repeatable manual processes, then figure out what is repetitive or error-prone, and then automate those aspects first.
jfiscus
Rap Master
Is the bottleneck on communication/workflow in the departments, or is it machine capacity?
I've never known those laminating tables to be actually good or efficient, and having 3 r2r printers and only 1 r2r laminator/plotter sounds a bit off.
I would look at more efficient printers/laminators/plotters and go from there.
jochwat
Graphics Department
Love your avatar, myront. It truly give me piece of mind.
jfiscus
Rap Master
If the issue is business/job management, we had custom software built for us around 8 years ago, and recently outgrew it. We looked at all of the software out there and it either seemed too simple or way too complicated and in the end decided to have another piece of software custom written to match our workflow here.
Ryze Signs
It's hard to say what you should do because every sign business is a little different. A simple Google sheet that multiple users have access to is a good place to start for free. That and a file server so all job files are organized and accessible on all your machines can do wonders.
From your equipment list it sounds like you focus more on printing. We are more fabrication oriented and have a router, fiber laser, CO2 laser, channel bender, cnc press brake, Roland printer, laminator, plotter, and several welders.
  • Agree
Reactions: 1 user
ONYXtechtips
I think Align can handle all of those devices with the use of Modifiers. Essentially estimating the amount of time it will take for each action and associate a cost to it.
donnyblazaroboe
As someone mentioned here, I also think sheets can do well for this type of thing. I'm not against automation tools, just they're not always necessary or that easy to work with.
ADVANCED DISPLAY
ADVANCED DISPLAY
We use Filemaker for our work order system. It allowed us to build custom work orders for our product mix, track all work, bill our work and it does a little automation for us. For example, we use an applescript/msdos script to create a folder structure with order number, name etc with subfolder for Supplied, Working, Proofs and Ready to print. Once an order is billed the job is archived. We also use 3rd party services to tie in to fedex with NRG Software, an extension to allow us to process cc's and another to post our invoice to QB using QBConnector. We run Onyx which has some hot folder functionality for a little hot folder functionality for ripping files. I am currently looking a using Switch by Enfocus which is a customizable hot folder workflow and can be combined with PitStop to automate some of the preflighting. I think this shows the most promise, but I haven't had the time to really dig in. As with any system, you won't be able to automate every file, but you can at least filter our the easy stuff so operators don't have to process and then kick out exceptions to be handled manually.
The downside of any automation is you will never find a canned solution that will do everything you want or need and all automation implementations will take a lot of labor. If you can allocation it internally, that helps or if you are willing to invest capital, you can hire someone to implement for you. I spend some time at Print United talking to the folks at significans.com. They are workflow consultants that can tie all the tools together.
HO-LEE-SHIT, you a programer or a sign maker? lol that uh.... that sounds like a LOT. I have so many questions, but I guess the main one is: who did all that ☝️ for you?
  • Agree
Reactions: 1 user
When you get in tune with your process, its easy to learn the nuances of tools. I use a bevy of tools to automate our workflow, we have achieved nearly zero touch between client order and production. There are always outliers, but its easy to find fix and adjust. Every product on our site is automated to production. All of our prepress operations run through OneVision, everything is linked to a database set and automated through ActivePieces and N8N.
FileMaker was a great tool for me early on but quickly became expensive, so I looked for other tools to expand with, and now Im developing our own in-house software to run all of our operations and just connect to outside tools.
Im self taught on everything and AI makes it incredibly easy once you learn how to prompt and leverage ides
  • Agree
Reactions: 1 user
ADVANCED DISPLAY
ADVANCED DISPLAY
Ok so, let me ask you this: the majority of orders that get initiated in your shop: where's that happening? website, or something else? you mentioned the website is automated, any manual process to onboard new jobs?
DPICopy
A Google Sheets job log has worked pretty well for our small shop over the last couple years, but we're interested in the next level up. Maybe Trello or nocoDB fit the bill, our current production load can't justify a large subscription like Onyx Align. Hardest part, like others have mentioned, is getting staff to keep it up to date!
Here is a screenshot of our sheet as an example. Definetly a constant work in progress and still needs a lot of work!
Pauly
Printrade.com.au
A Google Sheets job log has worked pretty well for our small shop over the last couple years, but we're interested in the next level up. Maybe Trello or NoCoDB fit the bill, our current production load can't justify a large subscription like Onyx Align. Hardest part, like others have mentioned, is getting staff to keep it up to date!
nocoDB is good as it's FOSS/OSS software. We use it for internal data. Very powerful if you pare it wit n8n automation.
