Avery Etchmark Humidity Nightmares
zillion29
Hoping someone will have some advice/guidance on this increasingly expensive problem in our shop. Using a Graphtec FC-8600 to cut 48" Avery Etchmark. Ambient temperature is 70 degrees and humidity is 60%. This stuff buckles and puckers within 15 seconds of leaving the roll. When the humidity hits the paper, it just ceases tracking properly in the rollers and either goes off track or tents up and jams. The things I'm cutting are less than 5'. This material is always a summer challenge, but recently it has become impossible (their ever cheapening paper and vinyl formulations, I'm guessing). This problem only seems to impact Avery Etchmark and Avery SuperCast Gloss white. I'm attaching a pic of what happens within 15-30 seconds.
Has anyone found a workaround for this or experienced anything similar? Wish they had a synthetic liner option like 3M Dusted Crystal.
unclebun
Run a dehumidifier? How do you achieve air temperature of 70 degrees without having lower humidity? Our shop is air conditioned to 75 degrees and it makes the humidity 32% at this moment with outdoor humidity currently 80%
zillion29
These are all very good questions. The A/C doesn't adequately handle moisture. In winter time, the HVAC makes it nose-bleed level 10% humidity with the worst static you've ever seen. Emperor Palapatine levels of 1" arcing static.
add a dehumidifier (or 2 depending on theme size of that area). add a commercial humidifier for the winter. why the extremes at both ends of the spectrum? is the problem no insulation? I am surprised you don't have terrible overspray when you have static problems
BigNate
... or take a lesson from the old-skool offset printers. keep the shop climate controlled 24/7 (absolutely humidity), and then all media brought in rests for 48 hours to damp humidity fluctuations... if the media and the environment are at the same humidity level you will not have issues when unrolling. Run your own tests to see how long to let the roll sit in the environment before it is stable.
we have had intermittent overspray that we have finally (i believe) eliminated
stopstatic.com was an incredible help (although not the complete answer by itself)
we added static discharge cord as well as 3 ionizers
zillion29
The room where we do most production and material storage has an arched ceiling that's probably 20' high at the apex. More like being in a hangar or a church than a sign shop. So it's all one giant open space.
zillion29
The room with our Arizona is slightly less humid. My HP560 has the closed chamber for heating and printing, so it doesn't really cause any problems (the operating range for that thing, I'm told is 20%-80% humidity). It seems like, when it comes to cutting, only the Avery films are affected by humidity. Oracal and 3M much less so.
