Ok...so there's going to be a fine line here, but I think you’ll soon see how valuable the badge function is.
The first step is data entry, that’s a given. Usually that can be provided by the customer if it requires people’s names or other information. If it’s just numbers and simple text, you can type much faster in Excel or a text document (rather than SignLab) since you’ll not be worried about any particular formatting.
Once you open SignLab, you will create just ONE
sign blank. For me, I do a rectangle.
The next step is formatting your text with the proper typeface, kerning and leading. You only have to do ONE layout using the LONGEST lines of text to make sure you stay well within your required boundaries.
After the text is justified (for me it’s center justify), delete all the other letters of your sample layout and type in just a simple letter “O” on each line of text. These “O”s serve as place holders for the merged text.
In your case, you’ll have the
sign blank rectangle with two letter “O”s each on their own line and center justified (I assume).
When the text file is merged with the
sign blank, SignLab dumps the new data for each
sign into the template you made, and instantly duplicates an array of finished layouts according to the parameters you have specified.
That’s it…you’re finished. You don’t have to mess with tweaking 52 different layouts. That’s the beauty of the badge function.
Next time you run the job with new data, it will take even less time.
I had a friend walk me through this on the telephone, and I’d be happy to do the same for you. PM me if you’d like further help.
