Banding / Printhead Issue?
I have a Roland VG2-540 that i take excellent care of. However been noticing some slight banding in the cyan color only. Im wondering if you guys think this problem is caused by what the pictures shown of my issue is. Roland Tech came and serviced the Printer about a 9 months ago and problem was known at that time as well and he says i need a new printhead with no known cause or explanation of what was really going on.
I have scrubbed the head and tried to let the cleaner solution soak into the head as well and that helped alot of my banding but still getting some banding. If you look at my test print i have 1 nozzle that acts funny by showing a "ghosted or fainted" line underneath the actual nozzle. Its literally the only thing i can think of that may cause it... I have done calibrations and media gap adjustments but nothing seems to completely get rid of the banding.
Do you think banding is caused from this one nozzle? If not what do you think? And also do you have any advice for trying to get this nozzle fixed other than buying a new printhead?
Terry01
That slight deflection on one nozzle won't be causing noticeable banding. What temperatures are you running and is it only on certain materials?
Terry01
As Jim stated, showing us the type of banding is what is required. Cyan is usually mixed with every other color, unless you are spot coloring with cyan only.. You will also never know when your icc profile uses Lc or Lm
The Roland tech gave me a test print sheet to do on a weekly basis which will print basically like what is below but I will get a picture of the banding on Monday IMG_5037.jpeg
Service tech can run the service level micro dot nozzle test to determine that you will need a cyan head.
Unfortunate, but very common with TR2 cyan.
Reactions: 1 users
cornholio
I just had to replace a cyan head on a 6 month old VG3. (Under warranty)
I don't understand, why Roland doesn't do anything about the cyan problem...
Terry01
Have you performed a feed calibration?? Have you tried different inks?? Also looks like heat needs turning up to prevent pooling.
Yes the tech did all the calibrations and also got my opinion on making the proper selections. He tried his first then I altered while he was there after his suggestions and no matter what we did it never got rid of the banding. I will say it was a lot worse til he came and serviced it. Now it’s very minimal just drives me nuts when looking up close at prints.
Yes the tech got me to do feed cal and he set it to the best looking. I only use Roland tr2 ink. What temp do you recommend?
I have the same issue after so many years. Were you able to fix it or did you just buy a new printer?
Sorry for late reply but I have run many more calibrations and cleanings but it still has the slightest banding. I’ve just learn to deal with the issue. I don’t feel like spending $3,000 to get that one issue fixed
