banner price check
petepaz
i have a 40-48" x 25ft banner to print and hang
between 2 steel girders
using 15 oz banner material w/ aircraft cable and turnbuckles, snap hooks
(as recomended in fellers catalog)
i am coming out with $1,100.00 using estimate
my material cost cons to about $305.00
never installed this big so not sure aactual work involved
shouldn't be 2 bad with 2 guys
think i should be charging more?
threeputt
Makes it a bit difficult to guessitmate without some additional factors.
Such as: Are these all at different locations scattered around the county? What's the driving time between locations?
How high up on these girders are you attaching? Will you need lifts or special equipment to get up there? What method of attaching? Are these girders, as you describe them, already fitted with some sort of attaching bracket welded onto them? Or are you going to have to fashion something? Are all the banners coming to you pre-designed? or are they all requiring your layout? one single layout or 40 different? Are these single sided banners?
It seems that you'd have to have the answers to these and maybe more questions before you can fix a price.
petepaz
what that is a lot of info 3putt
and chicago the materials are that price based on the fellers catalog
in the banner section they give you a recommendation on how to hang in this situation
and 3putt the girders are aleady mounted perm. in the parking lot and it is only 1 banner the 40-48 is the height and i was going to wrap a cable around the girder and usr the turnbeckles and ratchet straps and the banner will be approx 10-15ft high
i think i can do it with just ladders
as i said this is the first time for this big of a banner install any tips are highly appreciated
I think you guys are reading this wrong.... he has one [1] banner between 40" and 48" tall by 300" long. It's going about 15' in the air and he's going to wrap the cable around the girders.
I think your price is low for banner and installation. Also, that's going to be very difficult to do with only ladders. How are you going to clip your hooks in the middle of the span ??
Last, make sure you put grommets in the four [4] corners, so you can tie the banner off [to the girders], preventing it from sliding left and right.
petepaz
thanks gino
you got it all
and for the hooks can't i just put them on the banner and then hook them to the cable from one end and feed it across like a closeline
That just means you have to bunch up the banner and clip them on one at a time top & bottom and then push it, do it again... and again.... and again..... for 25'. At this size, your grommets should be every two feet. top and bottom.
Rememebr in this kind of install, you don't want any slack. Those cables shoud be about 6" to 8" above the top and the same distance below the banner.
Si Allen
Do yourself a big favor and add the price of a lift on this job!
Lots cheaper than falling off a ladder if you get a gust of wind while hanging it!
PhillipM
Rather late to comment, but just in case someone decides to do this type of job I know of some pitfalls. Specifically be sure what you are tying the cables to are very substantial. When I was a newbie we tied a 4' x 25' banner on cables to two parking lot light poles about 40' apart and about 25' high. Parking lot light poles aren't designed for this load and when the winds came the poles were bending at least 18" toward each other. The banner died before anything else bad happened.
On the same car lot a few years and many managers later, I was told to do almost the same install, just a little closer to the ground. I refused but my competition didn't.
Attempt #1: Banner torn to shreds
Attempt #2: Tougher banner, better attachment- cables came loose.
Attempt #3: Turnbuckles on the cables very secure banner - 1/4" cable snapped
Attempt #4: 3/8" cable secured banjo tight with turnbuckes - 1000 watt light fixture shook off the pole and landed on a new car (it was a dealership).
