What are the most important aspects of laminating vinyl prints?
I have printed an entire roll of 30" vinyl (150' long,) that I would like to laminate with my SEAL EP42.
My first problem is that my print was wound onto a take-up (JV33) and it is not wound concentrically, and it is fairly loose. Should I adjust the torque limiter on the printer take-up to be a little tighter?
How can you tell if the tension on the laminate feed is set correctly? What's it look like if it's too tight? Too loose?
How do you control tension on your roll of prints?
Does anyone not use the sacrificial paper on the bottom?
I'm using cold laminate, and it is available in a width shorter than my vinyl.
Any advice is appreciated...thanks for reading this!
