Johnny Best
Shiraz RIP
How's their support?This doesn't exist, all options have issues, bugs, and glitches.
I have used Flexi, and it's great for starting, but lacks the power for a high-output shop.
Caldera is great because it has a similar usability to Flexi, but you are stuck with Mac or Linux and their Support has gone downhill after their buyout.
We have been Onyx Users for year's, once you learn how it works and how to use it, it is a very powerful tool with great Color Management.
Ultimately we have decided to switch to PrintFactory, it provides tools and options far superior to any of the others, along with Excellent color management and production automation tools.
PrintFactory? It seems great, we have hit a roadblock with our integration due to some factors out of their control but beyond that they are responsive and very knowledgable.How's their support?
I can help you with that, we run different layers/colors all the time for that very reason and we use the summa also.I bought two new Epson printer that come with a stripped down version of Onyx. I called Onyx and spoke with them and the gave me a sixty day trail and have been extending the trail because of a bug.
I am looking at print factory after waiting for six to eight month on free trial of Onyx for them to fix a bug where if your file has a kiss-cut-and a thru-cut Onyx sees both cuts as the same no matter what you do. This is on a Summa Cutter. I have to run an entire role through and kiss-cut it, then print the file again using only the thru-cut. I had to figure out how to keep the bar code the same and reprint the file without actually printing the graphic.
This is basically making me do each job twice.
They keep telling me we are working on it, but I guess that is a standard reply.
Yesterday, when I called again, tech said they were going to ask the developer working on this how long until a fix is made. I told them I wasn't buying the software until the bug was fixed and that I have started to look at of rip software..
So you never moved from onyx yet?PrintFactory? It seems great, we have hit a roadblock with our integration due to some factors out of their control but beyond that they are responsive and very knowledgable.
Not fully; we are having an issue with profiling on the Colorado M5W because a glitch was discovered in the Colorado printer software that causes our profiles to be completely reset.So you never moved from onyx yet?
scaring me hereNot fully; we are having an issue with profiling on the Colorado M5W because a glitch was discovered in the Colorado printer software that causes our profiles to be completely reset.
Hey Christian, I'd also be interested in hearing some tips to get different cuts to work well through Onyx to Summa cutters!I can help you with that, we run different layers/colors all the time for that very reason and we use the summa also.
I'm jumping the queue, and you've probably already tried some of this, but this is what I do:Hey Christian, I'd also be interested in hearing some tips to get different cuts to work well through Onyx to Summa cutters!
This is exactly it. Sorry for my delay, but as Saturn mentioned, you can create 50 different layer names if you want... But you need to also have RIP server look for those in the quickest for cut path names and you need to have those spot colors in the input file.I'm jumping the queue, and you've probably already tried some of this, but this is what I do:
You should be able to get a "regular" cut and a FlexCut in one job by having your cut lines named specifically in both the file, and the >Manage Cutters>Cut Layer Settings window of the Onyx Cut Server.
For example, I have my everyday/default cut called 'CutContour' if I'm just doing my usual stickers. And if I am doing something (like a sticker sheet) where I want a kiss cut of little interior shapes followed by a flexcut or two around the edge, I have things named 'CutContour_KissCut' and 'CutContour_FlexCut', and that works great to get them both going in a single pass of the job. The key being having them named identically in the file and the cut server preferences.
What would be really great, is if Summa truly allowed 2 (or more) regular cuts where you could specify the weight individually at the cutter, and not be forced to use the FlexCut option. FlexCut, as far as I can tell, will always cut in a sort of 'Directional' mode even if that's not really ideal. It's also slower than a regular cut. You probably already are, but definitely set FlexCut options (weight speed etc.) at the cutter and not through Onyx.
