Best T-Shirt Material...
Tony Rome
OK, I know it is a sign forum, but I know some of us get involved with printing some T-Shirts.
I am wondering for those that may have a shop that does T-Shirts as well, what material do you like?
We screen print here as well, I am talking about doing a full color shirt with a solvent printable material and applying with a heat press.
I have used a few different types, IMO none of them are great but if you don't have a DTG printer or set up for sublimation, this is the only alternative for a small run multi-color.
Just curious what you like?
The one I use the most is Chemica Easy Print 1702 (but it is pretty thick)
My issue is when you get thin material you can forget about detailed contour cut, when I get the thicker material that you can get very detailed, it weeds great but...it is so thick on the shirt.
So, sticking with solvent printable material...what have you liked using for detailed contour cut?
rjssigns
We use Eco-Print from Imprintables Warehouse. Haven't done any super detailed cuts, but for what we've done it works great. Mike Koval can get you set up.
We use the crap out of Eco-Print from Imprintables Warehouse.
Weeds great! Prints great! No drying time.
from the printer to the press and looks/work great
fresh
I like Sihl T-Printz. Its thinner than other materials I've used in the past, and wears well. We also haven't had any problems weeding it.
phototec
I have only used Eco-Print from Imprintables Warehouse, prints good and no drying time, however it does feel a little thick and heavy on the shirt.
I would like something with a softer hand as they call it, I will be following this post to see what others like.
phototec
Question for rjssigns and houseofgraphics, I see you both have Roland printers, what media profile are you using when printing on Eco-Print from Imprintables Warehouse?
:thankyou:
DirtyD
I've used Stahls SuperTec Opaque...
It is soft and thin, Print is ok...I could not contour cut it very well.. it seemed like the blade drags instead of cuts, I thought that it feels like a plastiky sticker slapped onto the shirt, but thats probably how they all feel as I've only used that for print and cut..
For my Roland I used the Profile built into Versaworks for Heat Transfer
phototec
Which profile are you using for your heat transfers?
In my VW, they have several choices:
THT: Textile Heat Transfer
TTRH: Garment Heat Transfer
HTM2: Heat Transfer Material (ESM)
HTM: Opaque Heat Transfer Material (PCM)
:thankyou:
DirtyD
:thankyou:
My bad.. mine only has one it is the TTRH: Garment Heat transfer... the print quality was good on the stahls stuff could be different on others Im printing with an SJ Pro 2 V 745 Ex
ayukish
:thankyou:
Hello! We have a profile specifically for the Eco-Print. Which printer do you have?
Thank you,
Adam Yukish
ayukish
Hmm. Hopefully I have one for the SPv. PM me your email address and I'll send a couple different options to you. Hopefully one will work!
Jackpine
Sihl T-Printz
I like Sihl T-Printz also for dark shirts and the one for light and white shirts. And it works with solvent and pigment inks.
BESTBLANKS
Printing T-Shirts
Hi, Perhaps we can help. We are a wholesale supplier of digital imaging solutions including sublimation, heat transfer vinyl, heat transfer papers, DTG Inks plus others.
Please see our website for more information: http://www.bestblanks.com/
We also stock name brand shirts for both sublimation and digital transfer printing plus hundreds of other sublimation blanks. Also with sublimation printing it opens the door to making new customers and up selling existing ones.
Please call us with any questions, we are glad to help. 888-431-7385 or 954-989-1250
Thanks for your post!
www.bestblanks.com
Thank you,
Adam Yukish
Can you send it to me? houseofgrafix@gmail.com
Roland SP300V for both VW and flexi
thanks!
:thankyou:
We use the same one for 3651g with less heat.
phototec
thanks!
Ok, I sent it to you.
Why less HEAT? I used the same setting for 3651g and did NOT change the heat, the EcoPrint material has a flat or matte finish and my prints did not POP, so I also tried Generic Banner and it worked better.
Had a problem with weeding.
In my head.. the more heat causes the vinyl to become "stretchy" and the blade seems to skip
