(Bi Directional is way off) Media Gap and Calibration are perfect???????
dreko
Anyone ever seen, experienced or heard of the BiDirectional printing being off (prints are blurry in the scan direction) and printing UniDirectional makes perfect prints. (However at least 2 times longer time wise to print)
Media Gap, Calibration, Nozzle checks perfect
Encoder film strip is clean
Is the Encoder sensor going bad?
What was your experience?
What was your solution?
thank you!!!
Goatshaver
Shaving goats and eating bushes
I know when my SP-540v was doing weird things like that I had to end up replacing the encoder sensor ribbon after replacing the encoder strip 2x and that took care of the issues.
Something to look into, just reminded me of my Roland.
  • Agree
Reactions: 1 user
dreko
This can happen, if the adjustment in service mode hasn't been done correctly. Happened on VG3/SG3.
Interesting... the media gap and calibration are done in the normal menu mode... but maybe I'll try in service mode. thanks
Please post a picture of the nozzle test print.
being that it is fine when printing a unidirectional then obviously you need to form M-gap or directional adjustment. What model printer do you have because it is called something different depending on which model. Also there is a standard and a detail mode. Please see the user manual for your model and you’ll find all of this
  • Agree
Reactions: 1 user
cornholio
Since he writes about Mgap, I gathered he talks about a TrueVis, because the was the first time Roland changed the nomenclature from Bidi to Mgap. We had some troubles with the automatic adjustments starting with the VG3/SG3 and the new sensor. So I thought that could be the problem...
A hint to what model he's writing about would definitely help...
dreko
Nozzle check/Test is perfect... no dropped nozzles or deflected nozzles
ParadiseSignsInc
In the settings is there a status bar setting? If so turn it on, and select "wetting" and to print on both sides. This is how we fixed our bi-directional printing. And the issues sound very similar.
dreko
Hmmmm.... I've never seen any status bar settings on the LEC2-300 print menus. Maybe this is in the service mode menu?
Which printer did you have these similar issues on? Print on both sides... can you elaborate?
thanks
Jim Hancock
Old School Technician
This doesn't apply to your printer. Did you do the head alignment in service mode?
