Suggestions Biiig decal on the ground
Bengt Backhaus
I've just been asked to install a giant "cake paper" on the ground.
It's 16 meters / 53 feet in diameter.
White vinyl with cut holes in it.
I know which material to use but i'm thinking about how to do it best.
My initial thougt is to cut in stripes as in my picture and install from the middle and out.
Am i right in thinking so, or is there a better way?
I havent done something like this in 15 years, so maybe my thinking is too "old school"
Texas_Signmaker
Very Active Signmaker
I did a 22 panel graphic recently, and that was the consensus. Mine wasn't 53' tall, but you've got a simple graphic so if you need to splice it won't be a big deal.
  • Agree
Reactions: 2 users
victor bogdanov
Yes install just like a dancefloor, you can watch a bunch of dance floor install videos on you tube. Go with a 6 mil vinyl so it does not stretch. The cut holes I would cut them with a perforated cutline pattern and then weed them after installation to avoid needing transfer tape of anything tearing/stretching
  • Agree
Reactions: 2 users
Boudica
Great idea on perf cutting the lacey pattern!
JBurton
Signtologist
I'd opt to print the pattern unless it's required to be void cut, even then I'd probably print it and trace it out by hand with a knife after install. I feel like my printer would provide more consistent lengths than my plotter at 53' end to end...
I'd also be quick to ask if they have a budget to cover a 5-10k install before worrying about it.
  • Agree
Reactions: 1 users
victor bogdanov
Flatbed cutter would be needed I'd say, risky on a roll cutter but segmented with reg marks should be ok
  • Agree
Reactions: 1 users
Bengt Backhaus
It's our nations capital that ordered it so money is no object (as always when they spend my tax money...)
  • Agree
Reactions: 1 user
Bengt Backhaus
Yea id run it through the printer
I'm now thinking that I might just cut the long stretches by hand and only cut the outer line in the plotter. Then I can use the full width of the roll and save some material/money. And then maybe cut the holes in black vinyl and put it on the white.
It's outdoor so it will be a cheaper european version of
3M™ Scotchcal™ Pavement marking film 3662-10​
thesignpost
Print would be better making the hole pattern the same color as the floor to give the perception of it being plotted give it bleed for your overlap use a wide roller with a broom handle, use air egress vinyl to simplify installation. trim the outside edge to your liking.
  • Agree
Reactions: 1 user
Evan Gillette
Lol on the cobblestones, that might be an issue. Like you mentioned, if its just white, intall blocks of plain material in bulk and just panel the decorated segments around the outside. Thats how alot of the dance floors are done.
JBurton
Signtologist
Is this for a wedding?
It's for the gubment, so I'm assuming trump wants a 53' diameter birthday cake for the fourth of July...
Whoops, Bengt is from Sweden, my assumption stands, just not sure who is ordering it but Sweden's birthday must be coming up, so they need a doily for the plate of meatballs...
  • Hilarious!
  • Agree
Reactions: 1 users
