Billboard Wrap Pricing??
klemgraphics
Need a little help on this one as it will be my first billboard wrap. 12'x32', I was figuring about $750-800 including install.
Any insight is much appreciated!
wildside
that's the price for the banner and the install?
travel, lift, hardware, buckles? all included?????
wildside
384 sq ft of banner, at $2 a square with no design, travel install, etc already eats up that price
now if the contract they are paying you on the monthly makes up for it i could see that price as they would be paying you the rest over time
we do not typically do billboards, but here is what we know about this area
a 12x32 billboard depending on location will run about $400 a month with a 12 month minimum, initial $1200 for the production including design and install. That $1200 is basically the first three months in advance to get it put up so at the end of the year you have $4800 total into the billboard, and if anything ever happens to it, the client is not on the hook for any reproductions, and the longer the contract the lower the monthly investment for the board
tattoo.dan
I did 2 8x20 before for $800 each (first and only ones ever done) and I won't be doing another for that little money again. Yours is quite a bit bigger so I would say it is pretty low.
MatthewTimothy
bucket?? where exactly is it being installed??
ground crew: 49.99 per hour
bucket truck: 99.99 per hour
will be a two man crew easily for that size.
the banner you are pricing is around 2 dollars a sq. ft. Kinda cheap, what is the material you are making this out of?? My biggest question is what is your travel time. If you are using a bucket truck 3 hours away, you already priced yourself under the ground.
klemgraphics
Glad I posted here first!
I was quoted $0.50 psf for the banner and the layout is simple, figured about 8 hrs labor for the whole job including travel.
So double the cost on banner including shipping is about $400, labor $400.
This thing is on the ground also(bottom is about 1' from the dirt) in an easy location so the install "should" be fairly simple I would imagine.
Maybe I am forgetting something since I have never done one of these before?
I appreciate the advise!
allamericantrade
To give you a better idea, your price is about 20-40% where it should be and thats not knowing the height of the Bill Board. You could be worse off than that.
MatthewTimothy
well you are pricing yourself for a perfect world, which in the sign case is NEVER going to happen. You need to price yourself for a profit, not to break even. 1' off the ground is cool, but you are not pricing for a second or maybe even a third person, and at travel time and 8 hours is kinda cheap. You also didnt mention if this is going to be anchored in a wall or what. So you also have to include wear and tear on the drill. I know for a FACT that you will need a good impact drill and three charged batteries. I installed a 5' x 30' banner 20' off the ground anchored in brick and had to use a boom because they had a steel awning.
One of our guy's son is in this business and has many billboards around some counties.
He can install several 14' x 52's in a day's time. Two men and they basically work off ladders.
  • Is this a traditional billboard with catwalks ??
  • Are there ladders systems already there ??
  • Is there a flex-face already in place ??
  • Can you use any of the old gear over again ??
Now for the more important questions.........
  • Are you insured to be doing this ??
  • Not ever doing this before, do you know how to do it ??
  • This is a small one, but you still are gonna probably be high in the air. Are you Okay working at heights ??
  • Can you obtain permits to legally do this ??
  • Is this sign along a busy road or highway ??
klemgraphics
So maybe I should be more in the range of $1200?? I don't want to be a lowballer on this at all, I'm higher than most other shops on almost everything else.
This is why I can't get enough of this forum! Thanks so much for all of the advise!
klemgraphics
  • Is this a traditional billboard with catwalks ?? No, wooden posts & MDO
  • Are there ladders systems already there ?? No
  • Is there a flex-face already in place ?? No, blank MDO right now
  • Can you use any of the old gear over again ?? Don't think there is anything there.
  • Are you insured to be doing this ?? Yes
  • Not ever doing this before, do you know how to do it ?? I think, but maybe I should do a little more research
  • This is a small one, but you still are gonna probably be high in the air. Are you Okay working at heights ?? Been over 20' on a ladder so this shouldn't be a problem.
  • Can you obtain permits to legally do this ?? Yes
  • Is this sign along a busy road or highway ?? Not in a city, recreational area that gets a good amount of thru truck traffic. This matters why?
This is always very helpful Gino, makes someone like me see everything that I may have overlooked!
MatthewTimothy
well gino has some valid points as well. DO YOU NEED A PERMIT TO DO THIS??
MatthewTimothy
No permit required where it is located since the structure is already there.
not actually true, based on a local county we have you are regulated to install banners in this nature because it is not "visually appealing" to travelers. So you might want to make sure your statement is accurate.
Well, some of my original concerns won't have any affect on you, since you're working basically on the ground.
Anyway, that particular item was because if you're near a busy intersection or a roadway where there are lots of 18 wheelers and chit going by, that creates some gusty winds when you're up higher, not to mention for someone new, it could literally scare you when one of these big boys hit their brakes or make other loud noises.
wildside
when you said billboard, i thought thats what we were talking, your talking just a post and panel....
still at that size, no matter what anyone quotes you to print it, and 50 cents a square foot, wow, keep in mind you are going to need to make enough money on it to replace it minimum, what if the wind catches it or something gawd awful happens at some point and you have to fit the bill to replace it
at the new scenario you are talking by time permits, labor, travel and install are done, would easily be pushing 2000-2500
klemgraphics
I guess I better double check! First person I talked to at the county said I did not need one, they tend to be a little less than knowledgeable though.
MatthewTimothy
second this
i know when i was trying to hang that banner the fuel pump on the generator for the boom went out. Then we had to go to home depot and rent one, well the one we rented, the stabilizer was out and wouldn't allow it to level so we could use it so we had to go to another home depot for another lift. By it was said and done we were installing till 3am with the local metro watching us in aw because we had three trucks there running their brights and spot lights to see. I broke even on the install but made a profit on the banner.
You might want to re-think your knowledge on this one.
First of all.... never rely on a verbal from any municipal person. Get it in writing or you'll be sorry.
For the most part... country-wide.... state-wise.... county-to-county and town-to-town...... if you are doing ANYTHING outside [out of your shop] where you are working, regardless if you are painting a post or putting up huge sign, everything needs to be documented and permits need to be obtained to first, prove you are indeed a professional, next you have adequate insurance to do said job and last and most important, to clear the municipality of any negligence that might occur from you, so the municipality is not held accountable for any if at all any mishaps you create.
What if a ladder falls, hits a hammer, sends it through the air and hits a passing car or pedestrian ?? The municipality has to be assured if you aren't properly insured, the victim won't sue the city for damages..... especially now that most of them are broke to begin with.
