Need Help Blurry text 2 month old machine
Micheal
I have a brand new xg640 i had the head replaced because some nozzles are missing after that I noticed small text was blurry compared to my old printer however I dont know if it was after replacement or whole time.
Ive attached my print test and alignment test
And the blurry text its almost like.droplets are being misplaced outside of letter. My friends old roland prints it perfect
Any ideas?
netsol
And it’s not a profile with lower resolution or having head height too high?
possibly static causing overspray (it is winter heating season)
Micheal
No print head is low and calibrated to that height. I doubt it's static i print in this same condition for last few years with my epson there. Ive done all possible setting variations in fact it looks best in low quality with least amount of passes.
Is there a test to see if printhead is installed correctly?
dlndesign
If alignment and profile are correct. Heads are clean. Id try unidirectional but I do not know what size the text is but that would be a workaround until you get the bi directional to work.
Micheal
Same results on uni , text size is acceptable I had my buddy with old roland print and his is crisp compared to my brand new one...
Make sure the text isn't in RGB black which is a flood of all 4 colors. I've seen that before if the text is not just 100% black. Even if the heads are aligned perfectly sometimes RGB black is just too much ink
