Bombs Away
RedlineMan
Hey;
I have no illusions that ANYONE is going to like much of anything here. Hard to read, too busy, etc., etc. Just looking for little tweaks and ideas to improve the basic layout. I've looked at it too long.
geb
A good rule of thumb to remember is red and black don't go together, usually most will not use that combo. Try a white or light color outline between the red and black for starters to break that up.
George
Stevo
What Geb said about the colors and it took me awhile to decifer what was in the circle. Dracula?
RedlineMan
Yeh...
Of course I've heard that rule of thumb. Why? thumbs have articulated joints and are flexible. :Big Laugh
Not sure I buy it. Does it make your eyes hurt or is there not enough contrast? This is for cut vinyl on the side of my white trailer. Large format. I can see the aforementioned problems in small scale, but the larger it gets, it seems to me this is not as much of a factor. Somebody convince me.
There is also the converse of that in that adding a white outline might also add visual clutter, which may be just "as bad." Just thinking...
Naw, man. that aint Dracula, it's Shock Dude! :Cool 2:
Gordy Saunders
I like the circular one best, but I wondering what it might look like if you use a tire. Would the tire take too much away from the shock.
skyhigh
The red and black would work better with a white space/offset border between the two colors
I've seen from a couple of your post that you love the red and black combo. The only way to convince you, is to try what imaSIGNr said and be the judge for yourself.
The difference will be SHOCKING.
PS. Experiment with a different font also....... please
Ken
I really don't like the cartoon guy in there.
Along the shocking theme, you may want to try a lightning bolt or electric arc.
Good luck.
Ken
I added this photo that I found at fotolia.
You could have someone print it for you.
Just a thought.
signguy95
I did a sign for a local business - 3' x 12' - with only the business name. Red letters with black outline.
In the parking lot the sign just screams at you, but from 200 yards out it gets hard to read!
Jay
Craig Sjoquist
red and black turn copy brown whats called muddy it up done it before whith even thin black outline still muddy add white outline yes it brightens it up like a light and gives life ...
liked the 1st one a lot ....except the middle does look a little nich type of customer..and not a fan of a decortive font in all caps, but not set in stone in any rules if it works...great start
freedom is not free
Flame
Red and black... one of the worst combo's but most popular. Looks horrible cuz it turns muddy.
Please change that.
RedlineMan
Hey Gord;
I like that one better myself. It was a response to not really liking the one with the black box at the bottom, which I did first. Interesting idea on the tire thing. Hadn't thought of it. But... our tires don't have much tread - certainly nothing you can see from the side - so the only thing that would make it look like a tire would be sidewall markings. Interesting idea, though.
RedlineMan
And I did...
I did try it with a white border around the letters, like everyone always says to. There are two factors regarding this that make me unsure of whether I want to go that way.
1) It could be argued that this added "visual clutter," as I mentioned in my other post. It does make the letter pop, but it could be argued that this does also look a bit busy in this application under normal viewing. If there were fewer other components around, I would then agree that the border was more effective. The busy-ness only goes away under "squint conditions", which would somewhat approximate a distant view.
2) Perhaps more in my thinking is the fact that this is for exterior cut vinyl on a large white surface, not published/printed matrerial. My feeling is that in this regard it is best to have the least number of components possible, and of the largest surface area. Edges are where decals start coming up, and the smaller the component the more likely it is to let go. My gut tells me that the adhesion goes up exponentially as the surface area increases. This is speculation on my part, and may not be a reality. I'm not a sign person, so I'm only going on intuition and surmize.
I've already got two layers of vinyl. One solution to having small thin components would be to layer a solid white piece under the exterior red letter to create a white outline. However, I have the notion that doing THREE layers of vinyl is not a wise move. Thoughts?
Which one? Exceptions to the fonts used were expected. :Cool 2:
geb
Use the white background of the trailer to your advantage. Meaning, use that as your white outline between the red and black, thus elimimating adding a third color white outline in vinyl. Now your applying red letters, a space which is your white outline(or your trailer background), then your black outline color.
George
RedlineMan
George
That HAD occured to me as a possibility. Thanks. Does anyone have an opinion on my hypothesis on adhesion & small pieces?
