Business card for thought
bob
Marlene Young said:
Bob, what do you mean signs don't make good cards?
It means exactly what it says, no more, no less. Which word don't you understand?
When a customer has a sign, business cards and other materials in print, they should all have the same look. ...deletia... If anything, I've found that designs for business cards don't make good signs.
If you accept that cards don't make good signs, which is true, why do you have a problem grasping that signs don't make good cards? Having the same look does not mean being the same thing. Cards are cards for card purposes and signs are signs for sign purposes. Signs tend to be decorations, cards an excercise in correct typography. Not that signs shouldn't be typgraphically correct nor cards be as plain as a nun's habit. But they are different in kind not just in degree and ought to be approached differently
The very next opportunity you have to set up a business card, force yourself to do it actual size, 2x3.5. Don't do any part of it at any larger size. See if you don't eschew your repertoire of fills, outlines, drop shading, distortion, etc. All of those things tend look like noise and bad printing on a card.
Hell, I'm probably the worst offender at this, My own card, which I change all the time, often looks like something that fell off the side of a circus wagon. Sometimes, done in a moment of clarity, it looks like a card. I know the difference but those times I just can't, or don't want to, control the urge.
Marlene
Hey Bob, I said that I found that designs for business cards don't make good signs as the designers don't take into consideration materials outside the print world. Designers pick tons of PMS colors that aren't available without adding more money than most are willing to pay so colors get changed. Fonts that are OK on a card are too wimpy for a sign so they get changed. What happens is the overall design looks nothing like the paper prodcuts. I've worked with designers for years and have run into this over and over again and end up re-doing logos, colors and fonts so that they work. No, the card doesn't have to look just like the sign but if there's a logo on the card, the same logo shloud be on the sign. If fonts are used on the card for the name and services, the same font maybe in a different weight should be on the sign.
You have your opinions and that's good as all ideas here are important as it's how we learn and grow. What you don't need to do is express those opinions in a nasty way. As soon as that happens, people get turned off to what you have to say. Threads turn into "Springer" like threads and that gets us no where.
