Canon Colorado M3 - Avery 1105+1060z wrap issues
soggywinter
We have been printing wraps on an Epson S40600 with Avery 1105 and 1060Z gloss laminate. We’re trying the same media combination with a Canon Colorado M3 for the first time.
We are printing in Gloss Specialty mode to avoid banding.
The graphics are full ink coverage.
Issues encountered
-The color distorts when the 1105+1060z is stretched even a little bit
-The 1105+1060z is more brittle and tears easily than when printed with eco solvent prints
-We get red artifacts around air release holes near rivets when heating prior to rolling the rivets
-The uvgel printed 1105+1060z isn’t sticking to rivets gracefully after heating and rolling.
Is there anything we should be doing differently with this ink and media combo?
Grizzly
It’s all about your print!
This could be an ink/media incompatibility. Not sure why. We print on IJ180cv3/ 8518 combo and don't get stretching artifacts unless we're trying to wrap a bumper or something with a lot of stretch.
We really only use the Colorado for trailers and box trucks and mostly flat surfaces and still use our Seiko Colorpainter solvent printer for full wraps.
UV ink is naturally going to be more brittle. It's sitting and curing on the surface and creating another layer
Solvent essentially melts into the coating and can make the adhesive more gummy thus more stretchy.
Solvent is still going to be better when it comes to stretching.
This looks a little like it got too hot and is reacting different than solvent ink
The first rivet looks really good to me. I wouldn't expect any more than that. Especially on a trailer/box truck.
Reactions: 1 users
balstestrat
Problem Solver
From what I hear from the colorado wrappers you wont ever be able to work it like a solvent print. Ink will eventually crack and the ink will make the vinyl more brittle.
I guess I'm just saying you have to adjust your expectations to the new normal so lower your standards.
TSC1985
We have an M3W have been using it for full wraps on most standard vehicles for full wraps: transits, trucks, flats and have not had any issues with those on the corners or mildly-deep recessed areas. There are plenty of examples of wrappers on here doing those deep Freightliner fenders with these UVGel prints. I think it just takes some getting used too for the difference in stretch and tolerance. Those rivets look perfectly fine for a box truck as even with eco-solvent printed material they will all look the same eventually.
Bonzai901
UV inks are not made to be stretched even if they tell you different, I have installed 3M and Avery wrap from different printers (mimaki with uv ink and konica accurio uv) and the vinyl feels like still wet and curls if you print and install the same day; HP latex 215, 360 and 800 prints feels totally different 0.jpg
I post this all the time. This is off a 1650 on 1105, you can wrap anything with the Colorado if you install correctly (cold stretch). We have done countless "impossible" vehicles, it comes down to the install. I find way too many people rush their installs and want to take shortcuts instead of doing it right.
soggywinter
Thank you!!
What laminates do your team prefer with 1105 and uvGel?
