CE6000-60 flashed with wrong firmware
Djeans
Hi all — I’m trying to revive a used Graphtec CE6000-60 plotter that appears to have been flashed with the wrong firmware (possibly from a CE6000-120AP). It powers on, but initially throws this error:
NG!!! DIP-SW = 0001
FIRMWARE = 120AP (AP DIP-SW = 0011)
I pulled the side panel and changed the DIP switches to match the installed firmware (0011). It then booted to the home screen successfully. However, any operation causes an error related to push roller placement — and if I disable that check, the cutter slams left and errors out, suggesting the firmware is for a longer model.
I contacted Graphtec support, and they pointed me to the latest firmware, but the plotter refuses to accept it. Using SEND.EXE, the transfer goes through, the plotter shows it’s receiving data, but at the end I get:
  • “Bad Firmware CE6000” or
  • “Checksum Error”
  • Using the UPDATE.exe app with version 270 is completely unresponsive.
This leads me to believe the firmware update process is checking the current model ID and refusing to overwrite itwith the correct firmware. To test that theory, I tried flashing the latest CE6000-120AP firmware — and that did install successfully, reinforcing the mismatch theory.
My guess is that either:
  • The wrong mainboard was installed (maybe a used AP120 board), or
  • It was improperly flashed in a previous repair attempt.
Has anyone successfully forced a firmware overwrite on a Graphtec plotter?
I'm looking for:
  • A key combo to force bootloader or recovery mode
  • Info on JTAG or serial access (if possible)
  • A known-good firmware dump (or even a tool to generate one)
I’d appreciate any guidance from the community. Thanks in advance!
Sincerely,
djeans
(edited for clarity)
Attila Nagy
Update app turns an online cutter to service mode.
There is a Key combo for service mode. and you might be able to use a send.exe to send the firmware file directly to the port.
Just like CE5000 firmware.
I cannot remember now, It could be left+Right, but not sure.
Djeans
Thanks for the reply. Holding down the left and right arrows on startup puts it in firmware update mode. Due to the mismatch between what’s installed and what I’m trying to upload, I can’t get any further using the normal firmware update method.
Attila Nagy
Do not use the update.exe !!
it sends other commands before the firmware data. Now the cutter waits only for the firmware file.
get the send.exe comes with CE5000 firmware. or PM me, and I share a copy on my cloud Drive.
Djeans
Thank you to everyone who offered help. I was able to get it working with the help of ChatGPT.
If anyone else ends up in the same boat, this is what I did that finally worked:
ChatGPT helped me use some command line tools that intercepted the firmware dump from the SEND.exe app for both the AP120 firmware and(what was installed in the plotter but would not work correctly) and the CE6000-60 firmware. From there it was able to help me compare the hex values between the two and re-wrap the CE6000-60 firmware to identify itself as the AP120 firmware - essentially telling the plotter that we were installing a new AP120 firmware, but with a "payload" that was actually the CE6000-60 firmware. That didn't "work" completely, but it did fool the plotter boot loader into deleting the installed firmware - the "payload" that ChatGPT helped me create was uploaded, but it crashed the plotter and it would not load past the flash boot loader screen. - BUT - that left it a "blank slate" that allowed me to use the SEND.exe tool to flash the correct firmware. After that I was able to use the UPDATE.exe tool to update to the latest V270 firmware.
Vassago
Changing ID codes on firmware can work, but it messes up the checksum - if the system still let's you flash you're fine, but otherwise you "Brick" the machine - the only way past that is to copy the flash memory from one machine to another by taking the chips out and reprogramming them. Most modern systems bypass that by having a boot mode, which only flashes part of the memory, so the boot loader will always be intact, stopping bricking.
