there is a chance the "Eye" is clogged. spray it with a air can. you need to make sure also, that your settings are correct. (of course, this varies. either way, make sure your print marks are the same size and diameter as the settings on the cutter under settings for "mark".  of course, don't print on holographic material. this never works...
