Channel Letter Face Replacement and Proximity when routing
Think713
Hey guys,
So we are being tasked with some channel letter face replacements and I'm trying to maximize the amount of material on these signs. Typically when routing acrylic I like to leave as much as 1-2" minimum between each letter so our table's vacuum has no problem keeping the letter down and theres no breakage with the acrylic.
What is the minimum you guys would push the distance between each one? I have a full 5x10' sheet mocked up for one sign, but to make it work there are some letters that are as close as 0.5" in proximity to one another.
JBurton
Signtologist
We almost never make the faces out of acrylic, it's just too brittle. Typically we use .177" white polycarbonate. When cutting new faces, we give as little as .25" between letters. In your example, nesting two E's like that... you're going to have a bad time. Mostly because the way the serif's are fully tucked behind one another. If it were two capital arial E's, well frankly even then I'd put them flat to flat rather than engage the legs like this.
When doing face replacements for an existing set, we almost never use the router unless we produced the letters, or unless we can get great final art to produce the letters from.
  • Agree
Reactions: 1 user
Think713
Yea thats what I thought. We were told on this job they have to be acrylic. Im not sure why.
As far as hand cutting, our guys didn't or don't feel confident enough that they are going to be clean enough to do it. But I'm kind of a middle man on this one. We've had letters produced 3rd party just from tracings/rubbings so I dont see why we couldn't do it. Its just a pain in the ass.
Think713
As far as I understood, polycarb doesnt adhere to julite... so do you have a suggested glue?
  • Agree
Reactions: 1 users
MikePro
i add bridges most things that I route (.04" thick x .188" wide). 3-6 of them manually added before a path changes direction, or across long-lines, is enough to hold and thin enough to just snap-off with your finger prior to trimcapping.
ultimately, i never need any spacing between lettering as I adjust my bridges after nesting so that the lettering will create a web of attachments throughout the whole sheet.
if I intend to max out the whole sheet, then I'll add a little 3M spray 77 contact adhesive on the last 1-2ft of material for a little extra grip on the table.
...and for polycarbonate, we trim cap with weld-on #58
JBurton
Signtologist
Gemtrim by gemini is our current trimcap of choice, glued with weldon 4 (the runny stuff) and followed with a couple of coats of weldon 16, the thick stuff in the tube.
When we were using jewelite, we used channelbond exclusively.
Are you using the vidon/jewelite or gemtrim?
MikePro
currently using Vidon. we still lightly use weld-on 3 for a "primer" and an 80/20 mix of 16&3 for a hard-glue line to finish.
not sure of our reasoning for the switch from jewelite, but I haven't noticed a difference.
JBurton
Signtologist
I think vidon bought the patent from jewelite, the packaging one day just said VIDON on it, but our distributor still listed it as jewelite.
I'm surprised I'd never heard of weldon 58, and kinda mad. Now I gotta get a tube of that coming. How does it work out when storing half a tube? Do you just toss it because the tip will weld to the case?
  • Informative
Reactions: 1 user
MikePro
the 58 is a two part urethane, we only use it to bond the trimcap to polycarbonate.
half-used tubes stay on the shelf just fine, as they only mix in the stick. i just put the original cap back on and toss sticks after use but it also stores just fine with a used stick on it too. ...its just a bit longer, and since we rarely use it I just resetup the gun with the 1:4 plunger for our Lord's adhesive, as the #58 uses the 1:1.
  • Informative
Reactions: 1 user
JBurton
Signtologist
Channelbond.
That what I wanna know which weld on do you use for trimcap to lexan
Channelbond.
The only thing I haven't seen channelbond glue to well is gemini's trimcap. Heck, you could glue a piece of acrylic to a piece of lexan/polycarbonate, but whatever gemtrim is made from really resists channelbond.
ChaseO
I glued some Jewelite to poly a while back and I think I used #55 weld-on. I could be wrong, I normally try not to make these too often. The glue seemed to store ok if you just let it dry in the tip and replace the tips, but in the 50ish mL carts, there isn't too much of a need to take chances with dried glue.
Think713
Channelbond.
Channelbond.
Do you have a product suggestion then for julite with the channelbond? If so, I'll go with both...
Think713
Channelbond.
Channelbond.
If you're putting perf on faces, would you do it before or after the trimcap? Ive only experienced it post the trimcap being on, but I think you should be able to do it prior yea?
MikePro
i always do the vinyl before the trim cap, less effort and a cleaner-look when it caps-over
the only issue is risk of over-glueing, and it bleeds onto the face while trim capping.
  • Agree
Reactions: 1 users
Think713
Cool thanks. Yea for some reason in my dumb brain I thought it was a necessity to do it post, but it makes more sense to do it first.
  • Agree
Reactions: 1 user
JBurton
Signtologist
APPLY VINYL BEFORE EVEN CUTTING THE LETTERS! It saves so much time, unless you're using something sub par that wants to lift off while cutting. 3m perf works extremely well.
Just regular old polycarbonate. I prefer tuffak as they produce sheets that are a good deal flatter than anything off the reel.
  • Agree
Reactions: 1 user
Think713
Right on... Yea were using some general formulations i think for this job. As long as the polycarb glue works good we're not too concerned about the perf. the trimcap will hold the edges down and avoid any lifting...
Think713
Yea I think everything we have is Tuffak. Good stuff for sure.
MikePro
i do this whenever possible, bonus points for using an upcut bit with the vinyl-side-down on the table. cuts super clean
also saves a TON of time applying & trimming individual letters.
