channel letter job, markup ?
Maverick Signs
i never worked w/ channel letters as far as pricing before.
here is the bid i got from a local metal fabricator.
was just ? as to what a job like this would be roughly.
here is the bid i recieved
letters= 2260.00 black and white plex.
contour cabinet=1575.00-with graphics
install all the above=1510.00-same trip
permit=275.00
the john deer cabinet is coming from a double faced
lit pole sign they had orderd before moving, so the one
face is being removed and closing in the back.
this is all direct mount, not on a raceway w/ 5" return
was thinking of a 20% markup
am i in the ballpark w this
I was making reference to the double pole cab now turned single face. How is the rear sealed up? Reconstructed with aluminum or sheet metal to pass a water test? Also it seems you will have some different illuminations at night that may look awkward. Daynight mixed with "Fries" (neon Illumination?) and another into the mix, a H.O. illuminated fluorescent cab. Your going to have 3 variations of white come night time, murky gray channel letters, most likely 6500 snow white for "fries" and now a lighting temperature of somewhere in the 5800 of cool white for your HO cab. My advise is illuminate your fluorescent cab with neon to match "fries" so you have the same white temp, and make sure it's the same acrylic.
Maverick Signs
thanks for the info. never thought of any of that.
put a call into the manufacturer to see about doing
as you sagested w/ lighting the cabinet w/ neon.
iSign
20% = around $1100.00
for that you will do what? ..all the leg work, carry all the stress, the responsibility, some of the liability, some risk (you somehow order wrong... sub won't fix free, client won't pay) ...taxes on running job through your books...
I'd rather make two flat4x8 signs for $1100
