Awesome!
- it could also be the ink joint valves which are the little pieces just above the dampers (those also have valves) or the cartridge slot needles clogging up, capping top not doing very well.... I've reverse flushed the cartridge slot needles before which helped at that time. Remove the damper from the line, then remove the ink joint valve, then in test menus open one cartridge slot valve then just push a little fluid into the line is how I did it.
Now for all the fun alignments..... Make sure to set the normal user feed compensation to zero (dot position will get reset when you run the service mode alignments). Then do the service mode slant, then the draft and fine Y, then the feed comp. Reboot the printer, then do the dot position correction for both fine and draft user modes. Then lastly verify the feed comp. I think that's all the steps if I remember right.
I always forget something and only discover it when we try to use some particular mode. Like running fine perfect and looks amazing then run a fast draft mode job and it looks awful. lol
