CNC Routing Clear Acrylic
Susan Stewart
chips need somewhere to go, they'll never go straight-up through the flutes and want to rub/melt against the material as you progress through the shape.
I'm a huge fan of doing a rough-cut first, anywhere between 0.02"& up to half the diameter of the bit offset from the final part, but leaving .040" remaining in the depth of the material to keep it held in place. then your single-pass final cut will have plenty of room to evacuate chips AND polish the edge as it cuts.
Thanks for your input!
johnnysigns
There's feed rate calculators you can search for online. We just cross reference the chipload of the tool for the given diameter you're using in the specific material. It's pretty simply math: chipload x RPM x # of flutes to get your feed rates.
