I hate saying this, but if, you're not good doing it dry, try Rapid II will work. Let the application tape remain on until you can peel it without lifting anything. You might need to leave and come back the next day. If that's too inconvenient, as your customer just to gently remove the tape 24 hours later.
why would you use app fluid with a air release vinyl?My first time using a RapidAir product I sprayed with Rapid-Tac and it was cold...MISTAKE. Took forever before I could pull off masking.
