Construction Company Logo
jholtman1234
Hey guys I was wanting some honest opinions on the logo I am creating. Obviously its a construction company. The client want's something with a simple feel and with a arc to it he doesn't like simple artwork and text like 90% of logos today. This will be a sign for out front of his company. It will be used for alot of marketing and signage. Also when it comes to substrate for the business road sign should I use wood or something like alumacor??
:unclesam:
Malkin
For inexpensive I would use DF Alumalite, rectangle shape. For a nicer look you could do painted MDO (or HDU) cut to shape. Raised lettering for an even nicer look. Install 2 SF signs onto 2 posts.
Rick
Your outline is off.
The sharp edges are not adding anything.
Too much space above "METZINGER"
The type may be too stylized.
zmatalucci
construction doesn't pass the squint test
(just the beginnings of an idea)
jholtman1234
I see what all you guys are saying! The outline was drawn from a sketch this is a mock-up. I will put up the finished with corrections tomorrow. The Font though is Guardian closest one I have to what I drew. Mosh totally agreed with spacing will correct that! I can't tell though mosh did you put some embose on the one you attached? thanks guys for the pointers 2 eyes are always better than one!!! Well in this case 10 Eyes are better than one!
Todd-sta
Zeth mocked up what I was going to suggest: The "Construction" needs to be a thin, sans-serif, with ample inter character kerning - like he is showing you.
I'd definitely ditch the extreme 'points' on the sign shape... and add some more space on the sign blank around the bottom so that 'Construction' doesn't feel so cramped and packed in.
