Corel X3 Cutting Master 2 1.50 "Failed to Load"
Hello all!
I installed all my software and info on a new Dell running XP pro a 2 weeks ago and got a message yesterday in Corel X3 when I try to use Cutting master 2
" Failed to Load C:\Program Files\Corel\CorelDraw Graphics suite 13|Programs\Scanvec403\Program\CorelCutPlugin.dll "
I searched aroung to see if anyone else had this issue but can really find any info. Could I be the only one?!!! If anyone has a quick fix or advice it would be a great help. I currently have my old system hooked up so I can run the cutter which is getting to be a pita.
SYS INFO -WinXP pro Corel X3 Graphtec FC7000MK2-75 - Cutting Master 2 1.50
PGSigns
load all the X3 service packs and then reinstall the latest version of cutting master and it should fix it.
Jimmy
chrisphilipps
I believe that you have to have Cutting Master 2 1.60 if you are running Corel X3. You can download it from Graphtec's website.
stillmagnolia
Actually I already tried with the latest version of CuttingMaster but that doesn't help. I suppose that the problem could be in the windows registry, but I'm not sure.I'm keep trying to solve the problem and appreciate any help!
stillmagnolia
I still can't solve the problem, the XP is not SP3!Unfortunately I don't want to reinstall the entire PC, there should be other solution!! HUH :banghead:
