Corrugated Yard Sign Pricing Help Please.
ZsVinylInc
Not sure where to start.
Now, we do screen printing in-house and at 25 I would be screening 1 or 2 colors. Any more colors than that, I’d be digitally printing.
Gino.....Anything above one color here would be a digitally printed sign on Oracal 3640 then applied. I am sorry if for some reason you thought that I would be applying 5 or 6 layers of vinyl to a sign. We own and run an SP-540V.
ZsVinylInc
Your pricing seems high and I believe your questions are more acurately geared toward the proper set-up of your Estimate program....not your business practices with coro signs. I'm about to set up my Estimate 2.0 tonight and will be happy to discuss set-up issues with you after that.
Thanks GB2 I just started using the 2.0 and was using an older version before.
Slamdunkpro
I've been using estimate for a number of years and I've always found it's single piece pricing ridiculously high. When I was using version 1 I'd always calculate on a quantity of 3, select override and then change the quantity back to 1 when people just wanted 1 sign.
In order to get single pricing more in line with multiples, you need to do a couple of things:
  • set your base design time to 0
  • set your minimum price to a small number like $5
  • turn off quantity discount; this will reduce the disparity between low production and high production numbers
OP which plug-in are you using?
luggnut
i use estimate too and on some things like coro i have to adjust, unless i just didn't care if i got any of these coro jobs. if i had enough work coming in i would stick to the estimate price for these and not care if i lost them.
the perceived value of a coro with simple one color text is low (i can get more for a car tag) so i price 1 at $19.99 and i am the highest in town. mutiples get discounts .... i try to get them to order 25+ and get i45 to print.
ZsVinylInc
Slamdunkpro I recently found out the trick with the base design time set to 0 and I always have the quantity discount defaulted to no automatically come on. I have to check the box when I want it to go into effect and I am using the Wide Format Inkjet Plug-in.
IF you gots a printer then why would you want to do vinyl? Printing is much cheaper
Techman.....since hearing a few people in the thread I have since decided to just offer these as prints and not as cut vinyl.
I have had i45 print things for me before but here is the issue...this customer needs them in a 3 day turnaround and i45 is in texas and I am in PA...Most likely the orders of 50 will probably be slim....I would imagine more of order of 25 or less and probably single sided...a lot of people around here don't do a lot of double sided unless it is a political yard sign.
I am going to look at my numbers once again a see where I am...I know that once I found out some more things with my pricing program and adjusted the prices down from what they are in my OP and then did some searching that I was a little lower or about the same price as Stouse.
Slamdunkpro
{threadjack}
FYI the Wide format plugin in V2 under costs jobs when the piece you're pricing is larger than 50% of a rigid sub strait. (huh?) For example; If you are doing 2 42x60 prints and mounting them on foam core, Estimate V2 doesn't understand that since FC comes in 4x8 sheets (we'll ignore 5x10 for this example) you need 2 complete sheets to do this job (64 square feet). It just calculates the cost per square foot and uses the size of the print; so it will cost out 35 square feet of substrait(plus waste percentage). This usually isn't an issue with commonly used substraits like Coraplast or Foam Core, but can be when you need a expensive specialty substrait where you likely won't use the remainder.
luggnut
You can set it up in estimate to automatically enter the entire size when you select substrate..... so under your substrate you could add for example "foamcore full sheet" and set it to calculate full sheet when you enter that particular item
ZsVinylInc
Ok Everyone I looked over my numbers over the weekend and here is where I am at...maybe these will be in a better ball park...I have decided I will just be doing prints no matter if it is one color or full color. Anything near 50 I will try and talk him into screening or subbing out.
Single Sided FULL Color
1 - $30
10 - $20.5
25 - $17.25
Double Sided FULL Color
1 - $40
10 - $22.5
25 - $20.75
Thanks everyone so far for all of your help on this.
Big Z
