cssamerican
What is the ink cost on a 260 latex machine? How does this compare to eco-solvent machines like the Mimaki JV33, Mutoh Valuejet, Epson, or a Roland?
			$40 per hour.
Fine... it's going to run you between .16¢ - .22¢ per sq. ft. (Don't forget to add in the additional draw from your power meter because of the extra heat the machine needs to cure the inks)
We are averaging, $0.18/sq ft for ink, $0.12/sq ft for heads (This is a high average), and $0.17/sq ft for cleaning kits (changing the container every cycles).
We factor on $0.47/sq ft for 8 - 10 pass standard ink coverage.
