STAR Graphix
NEWBIE  TO PRINTING!
I just got a Roland sp 540, semi used. The guy bought everything new in march and sold out. I had the tech guy come up and set up the computer and everything, check and calibrate last wed, everything worked great.
Didnt use on thursday, but printed all day friday. Laminated early saturday and went to cut and all of the cut lines were off. I used the manual to re adjust everything on Monday....same problem. I had the tech guy to come back today, any new prints printed, removed then reloaded cut fine(unlaminated), any old prints from friday wouldnt work. Said it was possibly in how it was ripped before final adjustments. I printed after he left,let it outgas just laminated and re-loaded. and back to the same problem. up and down movements cut fine.. side to side is off.
I cant tell you the "exact" specs on the Laminate except that it is glossy, but i was wondering if that the shine on the lam might be throwing the sensor off? or if I am overlooking something obvious. But keep in mind it prints and cuts fine without a laminate.
Thanks in Advance!
Thanks in Advance!
