Cutting down a Roll of vinyl to fit cutter.
jmmccann
Has anyone ever cut a roll of vinyl on the core? I have a full roll of FDC matte black vinyl that I can use, but it's 8 inches too long for my cutter. Has anyone ever had to do this or have a good idea on how to do it with out ruining the whole roll?
Ken
When I have oversize material I just roll it out on the table and cut what I need off of it.
Try to find a supplier that has a slitter. They will prob want a few $ to cut it but the slitter does a nice job. I would not try to use a table saw but a band saw might work.
Perhaps just a fine tooth hand saw would work.
Ken
Tintman928
Find a mfg with a slitter as Ken said, if there are any window tint dist in your area, check with them as well, they will usually have a slitter.
Haakon
Have used a chop saw myself when the supplier has forgot to slit down the vinyl (I have a 24" vinyl cutter).
You are through the material much sooner than it has time to heat up, no melting to worry about. Cuts are a little more ragged than if you get ready slit vinyl from the supplier, but since this is for use in own cutter, that does not matter. If I were to deliver a roll of material to a customer I that would be another matter, but fine for own use.
GAC05
Quit buggin' me
D&Tgraphics
We have used a circular saw many times to cut down a roll of media. Use a fine tooth blade. Like stated above, it's a rugged looking cut but it will work fine.
showcase 66
I have used a chop saw as well.
What I use know is a meat slicer blade in my chop saw.
Works awesome that way. If you can find a flat blade meat slicer blade than it should work. The wavy blades not so much.
slappy
what if you need it exactly 6" to stripe something like a truck from head light to taillight... how can you guarantee it not be wavy with out a slitter? Or is a saw not recommended for that?
Mosh
FDC film? The best thing for that is in the fireplace...seriously, I tryed that film and replaced 80% of it that I used, save yourself some headache and toss it. The Maroon turned black and cracked in months, the black just cracked.
BUT, I got a deal on a bunch of app tape one time and I cut it down on my band saw with a fine blade, pretty sure vinyl would work too, in a pinch.
DizzyMarkus
Don't take the whole cut in one fatal pass :0) --Do the cut in three passes and you will be golden-- do it all the time as my lam machine is only 28" and the lam comes 30" :0) Keep the heat down and its works well. Gotten so you couldn't tell now lol
Markus
phototec
I use a Virutex slitter to cut narrow strips of vinyl, it uses a guide fence you can set for like a 4"' wide strip, run it along the vinyl and you get a precise factory finish cut. It's made to also slit plastic laminate, which it what I purchased it for, then found it could do a great job slitting vinyl also.
http://virutex.com/thegenuinevirutexlaminatesuperslitter.aspx
http://www.youtube.com/watch?v=l-_znDopSyU&sns=em
You can find used ones on ebay for about $50 0r less.
:thumb:
