This is more of an in the field hack, as the nut does clean out the troughs of the threads, it doesn't taper down the edges, so the stud is kinda hard to use in a blind situation. One of those little thread rounders does wonders in a hand drill at a slow speed.before cutting thread a nut on to each one, so it cleans up the threads as it comes off
jburton, are you famiiar with the saying "the perfect doesn't have to be the enemy of the good"?This is more of an in the field hack, as the nut does clean out the troughs of the threads, it doesn't taper down the edges, so the stud is kinda hard to use in a blind situation. One of those little thread rounders does wonders in a hand drill at a slow speed.
I'm cutting down aluminum one-way bolts. I haven't found them short enough. Although if I have full access to both sides if the signs I'm installing, is there a better vandal resistant solution than aluminum one-way and breakaway nuts? something that's just one way on both sides maybe?Is 5/16 the length or the diameter?
Get the bolts you actually need from any reliable fastener store . Far easier than screwing around attempting to cut off 60 of them.
there are about 1000 variationsI'm cutting down aluminum one-way bolts. I haven't found them short enough. Although if I have full access to both sides if the signs I'm installing, is there a better vandal resistant solution than aluminum one-way and breakaway nuts? something that's just one way on both sides maybe?
Rivets?is there a better vandal resistant solution
not that i steal a lot of signs, but, if i had my choice i would rather drill out a like number of rivets as opposed to one way screwsRivets?
While true, think of the cost savings to the customer! Which they can then use to replace the stolen signs, further saving money!!!not that i steal a lot of signs, but, if i had my choice i would rather drill out a like number of rivets as opposed to one way screws
TIL...These folks seem to have a wide variety of solutions: https://www.losspreventionfasteners.com/signs-public-art/
I'm actually fastening push and pull signs to opposite sides of a chain link fence, sandwiching the fence between them. both sides are user facing. I think I'm gonna go with these. Fun fact — a bolt with female threads inside its length is just straight up called a sex bolt! These are male and female sex bolts.While true, think of the cost savings to the customer! Which they can then use to replace the stolen signs, further saving money!!!
Then again, these rivets don't look as easy to drill out as ones installed with a gun.
That would make a great band name. The Sex BoltzI'm actually fastening push and pull signs to opposite sides of a chain link fence, sandwiching the fence between them. both sides are user facing. I think I'm gonna go with these. Fun fact — a bolt with female threads inside its length is just straight up called a sex bolt! These are male and female sex bolts.
Man, fastening to chain link is the biggest pita, haven't found a method I actually like. Only problem with these is if these are the wrong length, you may not get them tight, or you may get them bottomed out and leave the panels still loose. Not sure what would hold them tight aside from lock tite or maybe these have something like nylon threads?I'm actually fastening push and pull signs to opposite sides of a chain link fence, sandwiching the fence between them. both sides are user facing. I think I'm gonna go with these.
I'm with you though—I'd rather pick something apart than have nasty surprises (Boudica another great band name!) I made a small piece with through holes that I took to the site and made the chain link sandwich I'm going for. Outside dimension was virtually exactly 1". The fasteners bottom out at 7/8". They have serrated backs plus I am gonna use some loc-tite. I also measured so I could get the distance to separate the two fasteners -Man, fastening to chain link is the biggest pita, haven't found a method I actually like. Only problem with these is if these are the wrong length, you may not get them tight, or you may get them bottomed out and leave the panels still loose. Not sure what would hold them tight aside from lock tite or maybe these have something like nylon threads?
IDK, give me enough time and I'll find a problem with anything, these are probably perfect!
The ones like this that I have used are not really that strong. made from a light aluminum. Maybe yours are stronger.I'm actually fastening push and pull signs to opposite sides of a chain link fence, sandwiching the fence between them. both sides are user facing. I think I'm gonna go with these. Fun fact — a bolt with female threads inside its length is just straight up called a sex bolt! These are male and female sex bolts.
