Need Help Cutting Master 5 Issue
HarryS
So I've recently upgraded to the new "Cutting Master 5" and I've had nothing but issues so far. I feel like I'm on the only one. Most of my issues I've been able to fix but the big one I can't figure out is the following...
I can't use adobe Illustrator while running Cutting Master 5.
I'll go a little more in detail, when I have cutting master 5 open illustrator freezes until I close out the program. It sucks mostly because I can't work and cut at the same time now. I never had this issue with Cutting Master 4.
Before it's even asked yes, I've tried deleting the program and re installing it. Nothing seems to fix it. I'm also curious to hear if anyone else is having this issue or its just me.
JBurton
Signtologist
This issue in particular seems new and unique to you. Other headaches with CM5 have been bounding around since the new year or so. Hopefully one of the adobe users has a solution.
YepThatsMe
I would go back to CM4 to save you the headache.
I've been in the printing, production and design industry for a while and never had an issue with CM4. Once I upgraded to CM5 I've had nothing but issues and make absolutely no sense as to why a program would do certain things that as a customer we can't fix or isolate the issue to one specific incident or setting. The software engineers need to revise the program for all these issues people are having. I've had the freezing of Ai do to CM5 and got so fed up with the interface and how the software behaved that I just went back to CM4. So far no issues!
Joe House
Sign Equipment Technician
Check the version compatibility on the Graphtec website and make sure your version of Illustrator works with CM5. But also, go back to CM4 if you're having issues with 5 and 4 works for you.
Forty One
Make signs they said... It'll be fun they said...
What version of Ai do you have?
I found CC Ai 2020 and above is issue city with any version of CM.
I wound back to what worked, Ai 2019 and CM4 (4.2).
Even the cm 4.6 was problematic
L&Bdesignworks
Have you had any luck in figuring this out? It's driving me nuts having to close down CM5 every time I need to go back to Illustrator. In CM4 they had a mini dialog box that only needed to open once, then a secondary window when cutting.
Just seems to add in extra time when I have to close CM5 and reopen between cutting files.
L&Bdesignworks
And I plan to stay with CM4 as long as possible, but when Adobe discontinues AI22, then CM4 won't be supported. Thanks!
Stgmang
Once you've sent your file to CM5, it is no longer necessary to keep CM5 open. As long as the status bar has disappeared and the program highlights the X when you scroll over, you can close CM5. At least that's how it works on my Graphtec CE8000-60.
dypinc
How do you then send the job to the cutter without CM5 open?
Stgmang
My fault, I should have said that once you've pressed output, the status bar disappears, and the program highlights the X when you scroll over; you can then close CM5.
dypinc
But if you need to resend the job you have to start all over again do to lack of Queue like CM4. Which brings up the question, what is the menu Add to Queue supposed to do.
When I am not using the RIP to send jobs to the cutter I will just use CM4 until I can no longer use it
Stgmang
That's true. I'm new to Cutting Master, but I also noticed the lack of a save feature. I'm coming from using Silhouette Studio, so it's quite a bit different. I'm realizing my new machine will make cutting larger items easier, but it can't replace my Cameo 3 with Silhouette Studio for small decals. Especially multiple color decals.
dypinc
Doing some more testing and now a run into the Y Copy being grayed out. WTH
And is CM5 that much of a disaster that you can't rotate the graphic, or is it hidden somewhere I can't find it.
In Print
We refused to leave CM3. We run FC-2250 tables and CM-3 allows you to open multiples files - CM4 won’t allow that. The design computers use layer versions to make the files though. We just blocked any updates on illustrator on the computers powering the cutters. (Been a pleasure on new cutters that onyx builds and sends files to the hot folder - colex)
Humble PM
Mostly tolerates architects
I'm using a department of coloured crayons system (mac user). CM5 hands over to 2nd application (forget name), then in CM5, I click done, and I get to use illustrator again. 2nd app behaves like the rip component, and I have CM5 save the cut ile there (and I think I did with 4 & 3)
I've grown to not entirely totally loath CM5.
Almost.
