Shadowglen
OK printing on Orajet 3551GRA and laminating with Oraguard 290G so total thickness is 4.75 mil I have a new 45* blade that is clean and swinging freely. force is at 170 grams and the speed I have lowered from 30cm/s to 17cm/s all is good on straight cuts and radius cuts but when it gets to cuts that require tighter turns it is not cutting and lifting the vinyl. The test cut works fine. I edited my cut so that there wouldn’t be switchbacks. As you can see in the pictures I have the cut line of the graphic in 2 spots and the result cut. But it does this all over the decal. Do I need to go slower yet or will a 65* blade be the ticket? Any other suggestions would be great. The machine is a Roland SP540I and the laminator is a Seal 54EL if that matters just trying to give as much information up front.
Dave!
