MikePro
longstory short, cyan test print was gradually decreasing to no print at all. Initial assumption was either a clog or an air bubble in the line. flushed everything out, did multiple fillupink, and even pulled a LOT of ink through the line with a syringe to make sure I wasn't missing any bubbles.
Afterwards, the test print came out nearly perfect except the left channel was missing 4 entire grids at the top AND bottom.
pulled a syringe from just above the pump and I can hear the distinct "hissing" noise that would lead me to believe that the capping station isn't holding a seal. PITA since I just installed a NEW cap for the cyan just 2 months ago and everything was working fine until just now.
any ideas on how to fix without replacement parts? Would really like to not be down during shipping and I also can no longer find the individual capping station pieces from my normal suppliers, only the entire capping station.
also, if i were to install an entirely new capping station... is it as simple as plug&play or is there fine tweaking necessary?
. very simple to install. i have my old capping station witch is still fine if you want it i can ship it to you overnight i totaly cleaned it so all u need is to hook up the hoses and go. the capping station i have is im great condition.
