SignDesigns2004
Hello all, Here is a desperate plea for your help.
I recently purchased this sign shop, and with it came my 15" plotter and my 54" CJ/SJ-500 roland printer/cutter.
As of right now, my roland is non-functional. I am resorting to purchasing all vinyl print material from signs365.com, which drastically affects my turnaround time.
I need to get this roland working. Any help you can provide would be awesome.
The roland first had a problem with ink drain. One day i came in and it had drained all the RBK ink into the reservoir, but not the CMY. After replacing the ink, I had it working for a few more weeks. Then, the machine started to cut about 2 inches to the right of what I had printed. Before i could try anything to justify the cut, the printer began shutting off when the carriage would return to drop off the ink carriage before cutting. I found this to be a separation issue. It had been going too far to the right, so the locking mechanism would unlock right after it locked.
About this time it also would, in the middle of a large print job, about 4 feet in, start printing the image about 2 inches to the left of what it had been printing.
I then thought all this must be related to the linear encoder strip. I assumed it was dirty or scratched, which is why it would
a. set the heads at an odd seat which would lead it to drain through the night
b. set it off course so the cut would be off
c. set it off where it would travel too far when trying to drop off the head carriage
d.set off the printing.
I purchased a new linear encoder strip and optic sensor, but to no avail. same problems.
It has drained 9 RBK cartridges, and now if i even try to "set up sheet" the carriage slams into the carriage bay as if it has no idea to stop and shuts off the printer. Every time i turn it on I lose money, as it keeps draining ink.
As of right now, I'm clueless. PLEASE, any help you could offer would be much appreciated. Especially if you have seen this before our could point me in the right direction so I don't keep wasting ink as I blindly poke at the machine.![Pullingouthair :frustrated: :frustrated:](https://signs101.com/images/smilies-orig/standard/pullingouthair.gif)
