Did anyone build their own label finishing system?
bartlondon
As per title I'm wondering if anyone tried to build label finishing system? The purpose build ones are so expensive so I have had an idea to build one by myself. From my point of view it's Graphtec cutter, cold laminator and couple of rewinders.
Antnee
I wish, I need a label finisher myself. They are crazy expensive too.
DPR is the company that makes the finishers and they have a special camera and software to make them read the labels and cut custom shapes.
What kind of label printer do you have? I have an Afinia L801 with rewinder.
bartlondon
Currently I'm printing on Mimaki UV but I'm thinking about getting label printer. Yeah these label finishers are so expensie that's why I'm looking to build my own :) Not sure if it'll work but I don't see a reason why not
victor bogdanov
I'm printing labels on Colorado 1650 and cutting with Graphtec or flatbed , can easily compete on price with afinia systems because media 60" is so cheap
Was trying to figure out how to do roll labels efficiently and found this, ended up getting a laminator with the same slitters and I think it will be possible to weed and slit into rolls in one step. Will play around with it once it gets here.
About $1500 delivered
Just did 20k 2" x 4" labels at 8 cents each, 2hr print, 2hr cut on flatbed. cost me $300 in vinyl and $100 in ink to make.
Doesn't make sense to get a dedicated label printer for relatively small quantities if you have a decent wide format set up
Pauly
Printrade.com.au
oh damn, do you have a link for this??
victor bogdanov
Contact lefu/mefu laminator
I purchased the following from them on alibaba and they're putting 12 knifes on it
Raghaus
hi there –
I'm a little late to the party... what material are you using for labels on your wide format machine?
thanks!
White Haus
Not a Newbie
Did you end up getting this machine? If so, how are you liking it? I seem to remember you discussing it in different threads but can't remember now.
victor bogdanov
Makes sense. thank you. I was hoping to find info about wide BOPP rolls... I figure in the end it's all plastic anyways.
I looked around a bit for BOPP but there wouldn't be any advantage at the quantities I'm doing. I'm sure at massive quantities BOPP would be cheaper than vinyl (but also less durable)
