Does anyone know this symbol
SAR.Summerlin
So I have to recreate this sign and only have a low resolution image to go from. I will be doing it in Cut vinyl so I have to have vector. I am trying to figure out what the symbol next to the NRS in the lower right corner is called. I can't get a clean trace probably because it is friday. :smile:
The Vector Doctor
Chief Bezier Manipulator
section symbol
pc: alt key and 0167 held down at same time
On a mac or pc using the glyphs table in Illustrator you just double click on it
fozzie
On a PC hold down the "alt" key and hit 2 and then 1 on the numeric keypad. §" That works. Also, you can hold down "ALT" and type in (making sure "Num Lock" is on, and you are using the larger keypad to the right of the alphabet on your keyboard, NOT the numbers above the alphabet) "0167" then release "ALT."
On a Mac: "To insert these characters, press the Option key (bottom of keyboard) then other "code" key to make the symbol appear...§ Section Symbol Option+6.
or just type "section" or "sec.". thats what the symbol means
Jester1167
Don't know the name but it is alt + 0167
Or you can use START/WINDOWS ACCESSORIES/SYSTEM TOOLS/Character Map and copy and past it into your program.
